Haier HTE21WAAWW Top Freezer Refrigerator Logo
Anonymous Posted on Jan 05, 2010
My refrigerator haier hte21waaww doesn't work, just the frezzer,
My refrigerator haier model hte21waaww freezes at the top but not cooled in the bottom
  • Anonymous Jan 05, 2010
    It makes sense for the fan, now what my problem is where to buy the fan? living in Oklahoma I have searched online for the model of the refrigerator but still can not find
  • tkwasny Apr 24, 2017
    The "Cold-to-Coldest" adjuster in the freezer steals chilled air from the refrigerator to add more to the freezer. It's a mechanical damper. Set it fully CCW to cold (warmest position). I also put duck tape over half the chilled air outlets in the freezer to increase the chilled air pressure feeding the refrigerator section. Set the thermostat in the refrigerator to 8 or 9 and the freezer works fine and everything in the refrigerator is 38F.
Curtis Sewell
Level 3:
  • Haier Master 7,482 Answers
  • Posted on Jan 05, 2010
Curtis Sewell
Haier Master
Level 3:
Answers
7482
Questions
Helped
1943182
Points
24946
1...Check the fan that pushes the air from the freezer to the refrigerator it could be defective, if it is it will cause this type of problem. 2...Check your thermostat and make sure it is on the colder setting. I hope this helped you, Please rate me...Thanks
  • Curtis Sewell
    Curtis Sewell Jan 05, 2010
    If you have a local appliance store take the fan to them and I am sure they will be able to match it for you...
    If not then go online to the appliance dealers and find one with a chat line or phone number and talk to them about your problem.
    I am sure they will be able to match you one without any problem.
    Try this website, they list Haier Refigerator parts:
    They have a phone number and chat line.
    http://www.repairclinic.com/Refrigerator...
    Good Luck, I hope I helped.
Fan is a big issue. New problem though.
good day!first and foremost, in most freezers, the highest freezing point is 7.in regards with the water dripping from the air vent hole, you have to minimize your your freezing setting to the middle.turn it to 3 or 4 freezing point.
Haier
In units with physically separate sections, there is a fan that circulates the cold air between the two with some provision for adjusting the airflow to balance the temperature between the two chambers.
The cooling system is normally a totally closed loop that is charged in the factory through a nipple that is then pinched and welded shut.
This nipple must be cut and resealed to recharge the system.
Repair
Defrost system problem will be indicated by frost (snow) on back wall or cooling coil is located in the freezer compartment. Check freezer control setting. If it is set to cold for the freezer it reduces cold air to the refrigerator section.
Refrigerator
check to see if your condenser fan in the freezer is working
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
