I had the same problem with Goldstar DH404EY5.
The micro-switch under the power on/off button went bad.
I could not find a new switch , just drilled a hole in the cabinet
and mounted external sw .
Other micro-sw for setting humidity level also failed.
1) check power outlet
2) remover cabinet and check glass fuse on power supply board that power cord attaches to.
Hello friend, thank you for your post!
A dehumidifier is similar to having another refrigerator plugged in. It is recommended that it be plugged into a circuit of its own. If you are talking about the house fuse or circuit breaker it could be the circuit has to many products plug into the that house circuit. I would suggest moving it to another area of the house to see if it also blows that fuse. Hopefully this is helpful. -Matt
