Question about Goldstar DH504EL Dehumidifier
Looking for a replacment fuse #T3.15AL 250V
Posted by barry_snodgr on
Mark
    New Friend:
The cheapest place I have found is amazon. here:
QUALITY USA brand fuses Set of 5 pieces T3 15AL250V T3 15A 250V T3 15L250V... (you can search from another sellers, but this one had most positive reviews). I hope this was helpful. cheers
Looking for a replacment fuse #T3.15AL  250V - looking-replacment-fuse-t3-15al-250v-thwo3sxipgmgtjfqzhk52bks-2-0.jpg
Posted on Nov 29, 2014
Anonymous
    New Friend:
Radio shack carries T3.15A 250V fuses in 4 packs for 2.99
Posted on Aug 22, 2010
Anonymous
Go to www.mouser.com they have plenty of parts and should have what you want.
Posted on Apr 19, 2010
Anonymous
    New Friend:
I am in need for (5) T3.15A 250 fuses for a Husqvanar Designer 1 Embroidery Sewing Machine
Posted on Apr 18, 2010
Lightning got TV
My suggestion contact your insurance company. If it is less then your deductible trash it and get a new a new one. Lightning damage does not appear all at once, and you may have years of problems before everything is found. ESD damages semiconductors, we just do not know when they will fail.
Mar 05, 2014 | Haier Dehumidifiers
Delonghi dessicant type dehumidifier DNC65 The dessicant disc motor is operating but the other motor does not. I need a need a repair manual outling the the operation of the appliance to enable further...
Well although this is an old question, for the benefit of anyone who finds this in the future, the main reason for the main fan motor to stop working is due to the overheating of a tiny thermal fuse inside the motor itself. These fuses are one shot (meaning that if they trip, they will need replacing)
The good news is, that they cost about 99p to replace, the bad news is that you would need to strip down the unit and open up the motor in order to do that. This is a delicate operation and requires a steady hand, a soldering iron etc. the fuse you are looking for resembles a small resistor. usually located in a section of fibreglass insulation sleeve as the incoming wires connect to the motor windings. A fuse is easy to test using any multimeter a good fuse will show continuity and a dead fuse will show... nothing (open circuit) You would need to buy a replacement thermal fuse rated for the same temperature as the failed one (usually 115'C) and capable of passing mains voltage (240Vac) Cut out the old fuse and solder in the new one (it does not matter which way round it goes) Replace any sleeving and cable ties inside the motor and reassemble.
WARNING - do not attempt repair unless you are SURE you know what you are doing!!
Sep 22, 2011 | Dehumidifiers
EVERYTIME I PLUG IN THE UNIT AND TURN IT ON IT BLOWS THE 12 AMP 125 V FUSE INSIDE. REPLACED THE FUSE MULTIPLE TIMES WITH THE EXACT FUSE RECOMMENDED AND IT STILL BLOWS. THE UNIT IS ONLY 1-2 YEARS OLD. ...
The compressor has locked up and will not start...this is terminal and will cost more to replace it then the unit is worth...
unfortunately you will have to replace the unit with a new one...
heatman101
Jun 30, 2011 | Amana D545M Dehumidifier
FROZE UP NOW IT IS DEAD
UNplug it and let it sit for about 10 to 15 minutes and the built in circuit breaker will reset. The probable cause is the compressor can not start up due to the pressure in the lines so the breaker kicked in to prevent damage
Jun 20, 2009 | Fedders A7DH65B2A Dehumidifier
Kenmore Dehumidifier
I wonder if a little squirt of WD40 would go a long way in preventing the rust problem?
Sep 01, 2008 | Kenmore 54701 Dehumidifier
Location of Maytag M7DH45B2A motor fuse
I'm fixing one of these too. Take the top off (follow the AC cord) and the fuse is on the PCB.
I am also looking for a better wiring diagram - the control panel on mine does not light up.
Aug 21, 2008 | Maytag M7DH45B2A Dehumidifier
Fuse
Is there any way you could test the continuity of the fuse - or "jump" it temporarily - without heating it to over 130F, of course! Some thermal fuses can be broken without looking the part.
130F seems a very low temp... Can you post or send me the schematic?
Jul 15, 2008 | Maytag M7DH45B2A Dehumidifier
No Power
Found the fuse at this website www.tiewraps.com ORder the AG-12
Jun 27, 2008 | Haier HDN655E Dehumidifier
Blown Fuse on Compressor of Dehumidifier
That part is a thermal protector. If you can't find it at Radio Shack they should be able to direct you to an appropriate electronics store.
May 19, 2008 | Maytag M3DH30B2A Dehumidifier
Goldstar DH504EL Dehumidifier Logo
7,195 people viewed this question
Top Goldstar Dehumidifiers Experts
Tim Venetis
Tom Chichester
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
