20 Most Recent LG LHD459EL Dehumidifier Questions & Answers
0answers
0answers
Keeps blowing the fuse.
Sounds like its compressor is pulling too many amps trying to start, thereby blowing the fuse. That would indicate that the compressor is most likely locked up. If so, it's time to replace that dehumidifier. Repair by a shop is far too costly, and you're better off using those bucks to buy a new unit.
6/14/2014 9:23:47 PM • LG LHD459EL... • Answered on Jun 14, 2014
0answers
0answers
Machine runs, but no water is coming out into the
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture/humidity will be extracted from the air.
On most humidifiers the fan runs almost constantly while in operation. The idea is to continually move the air around and when the unit senses a rise in humidity, above what you have it set on, the compressor will turn ON to extract that humidity.
The 2nd thing that causes the problem is a dirty of clogged intake air filter. Which is easily solved by removing and cleaning the filter. Which should be done at least every 2 weeks, while the dehumidifier is in operation.
I said there were 2 reasons. Actually, there is a 3rd. Not enough clear air space all around the dehumidifier. A minimum of 12" should be maintained during operation.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
7/31/2013 2:48:58 PM • LG LHD459EL... • Answered on Jul 31, 2013
LG dehumidifer does not work
My unit runs but will not collect any water in container or when I use the hose.
7/11/2013 2:52:11 PM • LG LHD459EL... • Answered on Jul 11, 2013
0answers
2answers
Bucket full light flashes, humidity
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
9/4/2012 7:52:07 PM • LG LHD459EL... • Answered on Sep 04, 2012
Lg dehumidiffier will not start bucket is empty light says otherwise
We had a similar situation and the problem was solved when we removed and cleaned the filter which is accessible once the bucket is removed in the front (pull it down and out). Ours was very dirty and it sits between the humidity control dial and what we believe to be a sensor. Once cleaned, the compressor engaged immediately.
6/9/2012 8:24:05 PM • LG LHD459EL... • Answered on Jun 09, 2012
The top of the unit has alot of condensation on
A little condensation is not something to worry about. But, a lot can be caused by a dirty or clogged air intake filter. Which can also cause the cooling coils to freeze.
Turn the unit OFF & unplug it, before removing the filter for cleaning.
Also, maintain 12" to 18' of clear air space all around the unit.
If the unit is in an extremely moist or damp environment, 55% is not really a low setting. 35% would be more appropriate for this type of environment.
Hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
9/23/2011 6:55:54 PM • LG LHD459EL... • Answered on Sep 23, 2011
LHD45ELY7 DEHUMIDIFIER POWERS UP BUT
Check water pan to see if empty. Also check for loose or burnt wiring. Also check for internal resets or safeties
9/15/2011 4:41:06 PM • LG LHD459EL... • Answered on Sep 15, 2011
My unit is pulling water from the basement air but
Sounds as if the drain tube from the dehumidifier to the collection bucket may be clogged. Turn the unit of, unplug it and remove the bucket. With a flash light, look up into the rear of the cabinet where the bucket was. You should see a drain hole or short section of tubing. If you can see a clog, carefully remove it. If you can't see one. it may be further up the tube. Use some type of wire that is flexible, but yet firm enough to run up through the tubing or hole. Very very careful when you do this, as you don't want to puncture or damage anything.
The other option, if you have an air compressor is try blowing the clog back through the system, using fairly low pressure.
If all else fails, contact LG Customer Service (800) 243-0000
9/15/2011 1:54:31 AM • LG LHD459EL... • Answered on Sep 15, 2011
LG LHD459EL Dehumidifier Logo
76 questions posted
Top LG Dehumidifiers Experts
Gil Shultz
Jay Finke
Jay Finke
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
LG Dehumidifiers
  • LG Dehumidifiers
Most Popular Question
lhd45ely7 dehumidifier powers up but
  • Dehumidifiers
