1985 f-250 4x4 need to get to the front wheel bearings in the locking hub's
Jack up and support the front end on stands remove the wheel then remove the outer hub screws and then pull the hub out next you should see a large nut with square notches around the out side of the nut you will need the proper "spanner wrench"to remove this,once you remove the spanner nut there will be a large washer behind that with a small tab holes,that shim will pull out ,next remove the inner spanner nut(the same as the first one).This inner nut will have a small tab on it and fits into the shim you just removed make sure when you reinstall this nut and shim ring the tab and a hole line back up.Sorry I forgot to mention you need to remove the brake caliper also,just remove the two pressure rods(one on top and one on the bottom)by taking a hammer and a punch and gently tapping them outwards once they are out the caliper is able to be removed and swung up out of the way.Once the hub and inner nuts and shim are remove you will see the outer bearings and they come right out,for the rear bearings in the back of the hub you can pull out the old seal and remove the rear bearings.hope this helps its not as bad as it may seems once you've done one set they become easier for the next time
Testimonial: "yes great new's did just as you suggested and bingo got to the bearing's and adjusted them. Thank's so much for the no how. Roger Baltierra"
