Toshiba Regza 46RV535U 46 in. LCD HDTV Logo
Posted on Jan 02, 2010
Toshiba 46RV5354 replacement lcd screen
Anonymous
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Jan 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
8415
Points
52
Best of luck finding a replacement screen. Typically the screen is what get damaged and finding an exact model with some other issue is your only hope, that and finding someone to ship it to you as in most cases it's only local pickup. I think you'll find a replacement lcd (new) cost is way more than buying a new set. Best of luck.
MY TOSHIBA LCD TV SCREEN IS CRACKED DOES IT HAVE A
Hi Erika,
If your LCD is cracked, you will need to unfortunately replace the entire LCD. Simply putting a screen protector (which is just a thin film) will not stop the crack from getting worse. There is unfortunately no magical way to fix your screen other than simply replacing the LCD panel itself, which is totally doable. Many electronics repair shops can fix your TV pretty easily. In some cases, you can even mail it into Toshiba.
Toshiba satellite M305 S4907 comes on but monitor is blacked out can barley see
http://www.screentekinc.com/Toshiba__Satellite__M305-series-laptops-lcd-screens.shtml
The Toshiba Satellite M305-S4907 Notebook PC, uses a single CCFL for a Backlight.
Primer before we go on;
An LCD screen cannot produce light. It needs an additional light source,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
Click on the monitor image.
The additional light source is a Backlight.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height.
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
View the last 8 photos.
A screen Inverter is used on laptops that use CCFL for Backlighting.
A screen Inverter converts the power (Electricity), from the laptop, for the LCD screen, and Backlight.
Laptops that use a series of LED's for backlighting, do Not use a screen Inverter.
90 PERCENT OF THE TIME the fault can be attributed to a bad screen Inverter.
http://www.sparepartswarehouse.com/Toshiba,Satellite,M305-S4907,PSMD8U-02R015B,Laptop,Inverters.aspx
The plastic thin frame in front of the LCD screen, is the Display Bezel. (Toshiba = LCD Bezel)
The screen Inverter is located behind the Display Bezel, and mounted at the bottom of the LCD screen.
(LCD Screen Frame, actually)
Easy to get to; easy to replace.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M305/remove-screen-inverter-video-cable-1.htm
How to test a screen Inverter? Requires a Sensitive multimeter.
Read fairly expensive,
http://www.fonerbooks.com/test.htm
Because of this; and the low cost, plus ease of replacing; most home users just opt to replace it.
Know this;
Fluorescent lamps have MERCURY inside. HIGHLY poisonous.
Now couple that with the long thin makeup of the CCFL, and how easy it is to break it.
This is why if the screen Inverter is found to NOT be the problem; I would suggest replacing the LCD screen itself; instead of trying to replace the CCFL, and cause possible Mercury poisoning.
For additional questions please post in a Comment.
Regards,
joecoolvette
Blank screen when powing on, won't start.
Toshiba laptop LCD screen. It is to provide you with high quality laptop inverter replacement. The design of the Toshiba laptop LCD screen is 100% compatible with the Toshiba digital or model manufacturers.
Product Features:
1. Model: Toshiba laptop LCD screen
2. Each test notebook computer LCD screen before shipment, 100% of the working conditions:
3.100% new high quality replacement Toshiba laptop LCD screen
4. Toshiba inverter can be used for the other models and Inverter part No
5. Toshiba the notebook LCD InverterDefective backlight inverter can have the following symptoms:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
In good working condition. The best match for your device. High-quality, durable, easy to install. http://www.lcdinverters.net/Laptop-Inverter/Toshiba/Toshiba.html
Toshiba
Take apart and get a capacitor kit and replace any puffy or blown out capacitors etc. Remove and re solder new ones in. You can get kits online for you model LCD screen for external LCD monitors and you may need to replace the back lite on your laptop screen.......John
Need to replace LCD screen toshiba p105-s6024. need instructions to remove screen
Hello
First of all, I assume that your new LCD screen is compatible with theold one. Different screens require different video cables. Make sureyou new screen is compatible with your laptop.
Use the link below for more details and instructions.
http://www.laptoprepair101.com/laptop/2008/09/18/you-replaced-broken-lcd-screen-but-the-new-screen-is-not-working/
Regards
PCmania
2answers
Can the Toshiba Satellite L305-S5947 LCD screen be replaced????
Yes, it can be replaced but will most likely cost more than the computer is worth at todays prices. If it where me I would remove the screen and buy an LCD Flat screen and use the computer as a desk top if I really needed to keep it. Or remove the hard drive and put it in a mobile case and use as a back up drive and buy a new laptop.
Toshiba Satellite a105 s4004
Here, I found this:
Toshiba Satellite A105. How to remove and replace laptop FL inverter and LCD screen.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
Vertical black line on a LCD screen
LCD screens do not work the same as CRT tvs no vertical output IC, you have a screen fault which would need the screen replacing
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
