20 Most Recent Toshiba Regza 46RV535U 46 in. LCD HDTV Questions & Answers
Very low volume. have to turn up to over 40 to get any kind of volume.
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
4/20/2015 6:15:02 PM • Toshiba Regza... • Answered on Apr 20, 2015
0answers
My tv screen looks like broken glass but is smooth to the touch
sorry to say its busted, the cost of replacing the lcd will be more than the tv cost.
12/17/2013 2:00:24 PM • Toshiba Regza... • Answered on Dec 17, 2013
2answers
Plug in tv hear some clicks but nothing else
If more than one click----main power relay is turning on and then off.Indicates a problem in main power supply---either the supply or something connected to it is pulling it down.Suggests problem is on Secondary side of power supply.
12/13/2013 3:07:12 PM • Toshiba Regza... • Answered on Dec 13, 2013
2answers
46RV535U 46 in. HDTV LCD TV where is the fuse
There are several fuses on the power supply board. Usually the one that fails is not the main AC line fuse (which is close to the AC line input), but the PFC fuse located, you guessed it, next to the PFC regulator IC on the board. When the PFC fuse is blown (measuring open) you also need to replace the PFC IC and possibly other components on the board. Most of the time the PFC is sufficient though. Here's a link for repair service for the board: http://www.coppelltvrepair.com/p/751/toshiba-46rv535u-power-supply-board-repair-service-for-dead-refusing-to-power-tv-or-faint-display-problem Also search there for the TV model, we may have repair kits or exchange services available! Hope this helps!
12/13/2013 3:02:21 PM • Toshiba Regza... • Answered on Dec 13, 2013
2answers
No picture or sound
The 42RV530U is known to develop problems in both the power board and the main board. You can check out a power board repair service at http://www.coppelltvrepair.com/p/442/repair-service-for-toshiba-42rv530u-power-board-75010942-dead-tv-or-clicking-on-and-off-problem and you can also search for 42RV530U at http://blog.coppelltvrepair.com. Hope this helps.
12/12/2013 1:25:00 PM • Toshiba Regza... • Answered on Dec 12, 2013
0answers
Does Samsung tcon board fit Toshiba TV?
maybe we are smart enough to know better than to be inpolite.
12/6/2012 1:38:07 PM • Toshiba Regza... • Answered on Dec 06, 2012
I have the same problem with a Toshiba RGZA
The tubes are horizontal but require disassembling the cover and the inverterboard completelyfrom the chassis. There were 17 of these flourescent tubes stretching the ful length horizontally. They are so fragile.
8/24/2012 5:12:57 PM • Toshiba Regza... • Answered on Aug 24, 2012
The lower portion of my tv is dark with a distinct line dividing it. What is it?
Your lcd panel is faulty
2/7/2012 11:50:23 AM • Toshiba Regza... • Answered on Feb 07, 2012
Good Evening, I was programing the stations and
Redo the tv programming for tv channels again.Will be reprogramming the tv stantions again,all the tv station channels will come back again.
5/24/2011 6:39:12 AM • Toshiba Regza... • Answered on May 24, 2011
Toshiba 46 HD TV-1/2 Screen going out
I have a Regza 46XV648U. And sometime my sound will sound like a Echo Chamber, i can turn it off and the sound will be alright for some time.
8/22/2010 6:37:26 PM • Toshiba Regza... • Answered on Aug 22, 2010
Toshiba HD tv hooked up to a sony VCR-VCR player
You have crossed jacks somwhere in the back. Try another A/V connection. Move away from a connection ie AV1 to A/3 as an example. What happened is a common problem. It is very easy to cross paths!
1/26/2010 3:48:16 AM • Toshiba Regza... • Answered on Jan 26, 2010
Toshiba 46RV5354 replacement lcd screen
Best of luck finding a replacement screen. Typically the screen is what get damaged and finding an exact model with some other issue is your only hope, that and finding someone to ship it to you as in most cases it's only local pickup. I think you'll find a replacement lcd (new) cost is way more than buying a new set. Best of luck.
1/2/2010 3:13:34 AM • Toshiba Regza... • Answered on Jan 02, 2010
The speakers are partially muted thru the TV mode.
you mean with all tv channels too? there might be an attenuation setting somewhere that has to be de-activated. Check the manuals. hope this helps and pls come back for a feedback
8/19/2009 4:03:29 AM • Toshiba Regza... • Answered on Aug 19, 2009
Need to unlock side panel on Toshiba regza 42AV635DB without remote
Without a remote control, you can't. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. All the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check these sites too. http://remotesearch.blogspot.com/ https://elektrotricks.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops; as well as online shops. Visit the sites by Desktop computer and type in the brand name of your device in the search box at the right column. It will help you find the remote you have to buy. Mobille view has no search
8/30/2021 2:38:33 PM • Toshiba REGZA... • Answered on Aug 30, 2021
Toshiba Regza 46RV535U 46 in. LCD HDTV Logo
33 questions posted
Top Toshiba Televison & Video Experts
Ekse
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
REGZA Toshiba
  • REGZA Toshiba
Most Popular Question
46rv535u 46 in hdtv lcd tv fuse
  • Televison & Video
