Motorola Talkabout FR50 (14 Channels) 2-Way Radio Logo
Posted on Dec 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
One works the other does not broadcast - Motorola Talkabout FR50 (14 Channels) 2-Way Radio
eradiostore
Level 3:
  • Motorola Master 1,672 Answers
  • Posted on Dec 30, 2009
eradiostore
Motorola Master
Level 3:
Answers
1672
Questions
0
Helped
797177
Points
4248
The FR50 is a pretty basic radio, where you set the channel select to one of 14 frequencies. The freq number will display on the screen, both radios must be on the same freq to communicate. This being said, if you have known-good batteries and the freq number is the same, your raidos should work together. If not, you have a radio which is defective and will need to be replaced.
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/fr50_User_Manual_E.pdf
Best regards.
2answers
Will my toshiba tv bought in uk work in usa
There are two things you need to know regarding your TV.
Power requirements and broadcasting standards.
1:POWER
Look on the back of the TV and find the sticker or label that mentions the INPUT VOLTAGE.
If it reads 220-240V 50Hz then it will not work in the USA.
If it reads 110-240V 50-60Hz then it MAY work in the USA. At least you know it will work if you change the plug on the mains cable.
2: BROADCASTING
In the UK, broadcasts use the PAL system to display images on the screen. In the USA, broadcasts use the NTSC system to display images on the screen.
You need to check the manual that came with your TV to see if it is capable of receiving an NTSC signal. This signal is used in everything in the USA from PVRs, to DVD/HDD recorders, satellite systems, public access and cable systems.
If your TV meets the power and broadcast requirements then it should work.
What does RF CH mean?
What is the difference between a RF channel and a virtual channel? The RF channel is the channel that the TV station uses to broadcast its signal. Before the conversion to digital, TV stations were normally identified by their channel number, and most people knew that a particular network was on a specific TV channel. While analog broadcasting was being phased out and all TV stations were converting to digital broadcasting, it was necessary for the TV stations to continue to broadcast their analog signals on their original RF channels, and also broadcast their digital signals on a different RF channel. However, since the TV station used their broadcast channel as part of their identification, they wanted to keep using the same channel number. To allow this to happen, the new digital television broadcasting standards (ATSC) provided TV stations the ability to continue to use their original channel number and also tell the TV set to tune to the new RF broadcast channel when their virtual channel number was selected. The original channel number is called the virtual channel number, and it will be followed by a period and a second number (3.1, 7.1, etc.).
One of the benefits of converting to digital for the TV stations is that they now have the ability to transmit more than one program at the same time on the same RF channel. The number of additional channels they can broadcast is determined by the resolution of the program (SD vs. HD, text only, music only, etc.). The second number in their virtual channel number indicates that one of the additional programming sources from the same TV station is being viewed (10.2, 10.3, 10.4, etc.).
When selecting an antenna, it is important to understand the difference between the RF broadcast channel and the virtual channel. Antennas are designed to receive specific ranges of RF channels, and the antenna needs to be selected for the RF channel you wish to receive. TV stations broadcast in two broad frequency ranges, called VHF and UHF. RF channels 2 through 13 are considered VHF, and RF channels 14 through 51 are considered UHF. In order to pick up the channels, the antenna has to be designed for the correct frequency range. It is very common today to find that TV stations using virtual channels 2 through 13 are actually using RF broadcast channels in the UHF range. Although not as common, some TV stations using virtual channels 14 through 51 are actually transmitting in the VHF range. An antenna designed for only UHF channels will not work effectively for RF broadcast channels in the VHF range, and an antenna designed for only VHF channels will not work effectively for RF broadcast channels in the UHF range.
Cisco router does not broadcast
The wifi does not broadcast? Check in the setup page to make sure wifi is turned on and its setup to broadcast (It is possible to set it up to broadcast "invisibly" so strangers can't see the network and use your internet) RTFM
3answers
Why won't FM radio work on the Motorola 6310 two-way radio?
It's a two way communications radio, not a broadcast radio, hence it won't receive FM/AM broadcast radio stations.
You should not confuse the two as they work on different radio bands, most FM broadcast radios are on the 86-108MHz bands, whereas two way radios operate on the following bands:
1-86MHz, 108-174MHz, 220-520MHz & 865-920MHz
I don't know which band your radio works on, but not broadcast bands I'm sure.
The only exception to this is the smaller hand helds, which may have FM broadcast programmed, but if this is the case with yours, This issue is out of the realm of two way radio queries, as Broadcast radio is not two way radio, but one way radio, and I'm not competent enough to answer Broadcast radio issues.
Cheers, Peter@FixYa Team
) What feature of Powerpoint 2010 helps in broadcasting slides to remote audience
Dear Anand,
To broadcast your presentation, do the following:
  1. On the Slide Show tab, in the Start Slide Show group, click Broadcast Slide Show.
The Broadcast Slide Show dialog box opens.
  1. Do one of the following:
    • If you want to host your slide show on the service listed under Broadcast Service, skip to the next step.
    • If you want to use some other service to host your slide show, click Change Broadcast Service. Under Choose a broadcast service, select the service that you want to use. For more information about broadcast services, see Choosing a broadcast service.
Note If you do not see the service that you want to use, select Add a new service, and then in the Add Broadcast Service dialog box, enter the network address of the service you want to use and then click Add.
  1. After you select your broadcast service, click Start Broadcast. PowerPoint then creates a URL for your presentation.
PowerPoint creates a unique URL for your slide show.
  1. To send the URL for your presentation to your audience, do one of the following:
    • To send the URL for your presentation by email, click Send in Email.
    • To copy the link, click Copy Link.
  2. When your audience receives the URL for the slide show, click Start Slide Show to begin your broadcast.
The audience follows your slide show in their browser while you present within PowerPoint 2010.
  1. After you finish presenting and are ready to end the broadcast, press ESC to exit Slide Show view and then click End Broadcast.
After you begin broadcasting a slide show, the Broadcast tab appears in the PowerPoint 2010 ribbon.
Regards,
Tech_Comp
How do i change the time?
Hello, here is the instructions for setting the clock
RDS Clock Time Broadcasters can choose to send clock time information in the RDS data. This information can be used to update the clock time on the radio. RDS clock time is broadcasted once a minute. To set the clock using RDS clock data perform the following:
• Press and hold the HR and MIN buttons together for two or more seconds to update the time.
• The display will show "UPDATED" after receiving the broadcasted time data. • If the broadcaster is not broadcasting the time data, the radio will display "NO UPDATE" and the time remains unchanged.
if this doesnt work, just simply push and hold the hr and minute buttons to set the time
• Press and hold the HR and MIN buttons together for two or more seconds to update the time. • The display will show "UPDATED" after receiving the broadcasted time data. • If the broadcaster is not broadcasting the time data, the radio will display "NO UPDATE" and the time remains unchanged.
Ps3 wont broadcast cast right.
Try holding down the power button for 2 beeps. This will reset the PS3 video to standard mode.
1helpful
I have a Casio EV-570 hand held TV. Will this work after the switch over to digital broadcast.
According to CASIO website in Japanese, their portable TVs are not supporting Digital broadcasting and decided to cease production.
Thus it will not receive Digital broadcasting.
Although, EV-570 composite AV Input should still work for Camera, VCR, etc., I have not tried to connect to the DAC box.
My portable DVD without TV tuner worked with DAC box and now can watch digital TV program!
Ace orbicam broadcasting
I can not move the cursor anymore
Cisco 1242ag broadcast multi SSID issue
It stops broadcasting the SSID? Make sure it's configured to broadcast the SSID firstly... secondly, test whether it is actually working but just not broadcasting the SSID.
Set a client PC to the same SSID and get all the parameters identical (encryption, user/pass etc). Try connecting again. If it connects then it's just the SSID that isn't working... if there is no joy, then it is just the SSID that isn't broadcasting, not the whole AP.
Also, enable some debugging for the radio0 while it is not working. It might shed some light.
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
