My tv dose not turn on , its show power light red and when I plug in its sound like timer and , then screen turn grey, I can not change any mode or volume , and can not turn it off , I have to plug it out,
Re: My tv dose not turn on , its show power light red and...
Hello sir,
please sir solve my this problem.
my tv dose not turn on , its show power light red and when I plug in its sound like timer and , then screen turn grey, I can not change any mode or volume , and can not turn it off , I have to plug it out,
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV FIX ... 1. soft reset - is just turning tv off & back on 2. hard reset - unplug power to tv for 1 minute then connect power to your Flat-Screen
? 2:32
https://www.youtube.com/watch?v=kEDVc-BXf0I
May 1, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding ... I get a center led light when its plugged in showing power. ... I have a dynex 42 in and it dose not have stand by but turning on on the light but nothing happens ....Repairing Flat Screen TV - Blacked out with blinking red light ...
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
helloFive blinks - AKB circuit (automatic kine bias), the
timer/standby indicator blinks for about 30 seconds then goes to the
self-diagnosis function. Something is wrong with the video. Check video
out, Q705, 732, 761 and other components on the C board, also check
Q218, 219, 220 on the A board. In addition, unit could be in IK
blanking, try turning up screen slightly.
Not sure what you are talking about, this is a bit vague..... try this, on the back of the xbox there is a switch on the plug that goes to the TV, if the TV is not HI-DEF and you are using just the red + white + yellow plugs, then switch to TV, if your using the red + white + blue + green + red then switch to HDTV. Your Son could have also switched a setting on the dashboard to use HI-DEF, if he did, maybe switching back the TV mode on the TV out plug may correct the issue. Kids love to play with things! lol...
