RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
Posted on Dec 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Dell computer found problems and 1 said 'RCA Digital Cable Modem is not compatible with this version of Windows.' even though that's what I'm using to access the net wirelessly right now. Is there a solution?
Anonymous
Level 3:
Guru:
  • Master 1,738 Answers
  • Posted on Dec 04, 2009
Anonymous
Master
Level 3:
Guru:
Answers
1738
Questions
Helped
470982
Points
4963
Make sure you have the correct drivers installed for the correct windows.
How do I open a port on the RCA modem dhg534 to allow me to do remote deskstop within my network?
> open a port on the RCA digital cable-modem
This device has no "ports" -- all the traffic goes right through out, unfiltered & unblocked.
Connect your computer directly to the Ethernet port on the cable-modem
Configure the Windows Firewall to "open" any port(s).
I have a RCa broadband modem from Comcast. I want to connect my computer Fax card to it. IS that ok? How do I do it? Just connecthe telephone cable from the port at the back of the computer to the RCA...
Yes it is perfectly OK. Remember that a fax essentially works as a phone, so you would run a line from the RCA modem to your fax card, then from the fax card to your telephone. In this scenario you would have to accept your faxes manually though.
2helpful
Can i hook up 2 computers to the rca dcm425 without a wireless router
RCA DCM425 digital cable modems only have one Ethernet cable located in the back of the device. In order to have two computers connected at the same time you will need to have router. The router will connect to the Ethernet port on the back of the RCA modem and then you can have up to 4 computers connected directly to the router using Ethernet cables. If any of your computers are wifi compatible they will also be able to get online by using the wifi from the router.
1helpful
2answers
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Itunes .exe has been set to run in compatibility mode for an older version of windows. i already tried to change version but cant find windows 7 version also turned off compatibility still no luck
Unfortunately, even though I'd turned off compatibility mode for iTunes (by right-clicking the iTunes icon, choosing Properties, clicking the Compatibility tab, and clearing the Compatibility mode checkbox), the program generated this irksome message every time I ran it:
iTunes.exe has been set to run in compatibility mode for an older version of Windows. For best result, turn off compatibility mode of iTunes before you open it.
Sigh. Stupid Windows. Or maybe stupid iTunes. Either way, compatibility mode was "off," but iTunes didn't think so.
Fortunately, I finally found a solution:
1. Make sure iTunes isn't running.
2. Click Start, type regedit, then press Enter.
3. Navigate to this Registry location: HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry.
5. Start iTunes. The offending message should be gone!
Canon sb1100 digital camera compatibility question
i talked to a computer guy who knows a thing or two and also found the answer at the canon web site. the sd1100 will be compatible with my system.
Top RCA Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
NOEL
NOEL
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
