Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
What wireless is compatable with RCA DCM425 Digital cable Modem
Posted by Terrie on
David Payne
    Top Expert:
  • RCA Master
  • 14,162 Answers
MOST OF THESE WILL WORK WATH THE VIDEO.
Posted on Nov 29, 2014
Emmanuel Ronald Torres
    New Friend:
  • 23 Answers
Any wireless router would be compatible with your RCA modem. Just make sure to connect the ethernet cable from your modem to the correct port on your router (usually the yellow port, maked "modem" or "internet") and that your RCA modem is online (4 green lights - press the internet on/off switch if otherwise)
This way you're making sure that your wireless router is correctly facilitating your internet service.
Hope this helps.
Posted on Sep 29, 2011
Can you connect a router to a dcm425 router
Yes. My "home" network starts with the cable-modem, with an Ethernet cable between the cable-modem and the "uplink" port on my wireless router, and up to 4 computers connected to the 'LAN' ports on the router, plus support for my wireless devices (laptop, iPhone, tablet).
Nov 10, 2013 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I want to replace RCA DCM425 cable modem with new, compatible device to continue feeding internet (by ethernet cable) to my desktop (like the present) and provide new WiFi to the home. Please advise. Thank...
You have two choices to achieve your goal (which I understand is to have both you desktop plugged by Ethernet and WiFi throughout your home) :
1. The cheapest way :
You need not be replacing your cable modem, but adding a router to it. There are numerous routers which are WiFi enabled. You can then plug your PC to the router and have WiFi.
2. The cleanest (but less cheap) way :
There are cable modems on the market which will do the job, like the Motorola SURFboard SBG900 DOCSIS 2.0 Wireless Cable Modem. Once plugged in place of your old modem, depending on your provider, you will either have to download and install the software for your new modem (which should be prompted on your PC when you try to access the Internet), or call the provider to activate the new modem.
May 09, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
How can I install a wireless router to RCA cable modem DCM425 installed by Time Warner?
From the back of your modem, follow the ethernet cable to your PC (in). Mark or remember this location. Remove this cable from the PC and insert it into the INTERNET port on your router. Then take another ethernet cable (usually supplied) and insert one end into the ETHERNET port of the router, and the other end into your PC (where you originally removed it. Remember to check all connections and plug in the modem. You should now be good to go! If your PC has an installation Wizard, you can browse thru it as well.
Jan 07, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I need to change the channel settings on my RCA DCM425 cable modem. The problem is my company set up the router and wireless along with an ASA and I do not have any of the original information. How do I...
Cable Modem Troubleshooting RCA DCM425
or
You can change the radio channel on your AirPort Extreme using the AirPort Utility, as follows:
  • Run the AirPort Utility.
  • Select the AirPort Extreme, and then, select Edit.
  • Select the Wireless tab.
  • Select Wireless Options.
  • By default, the channels for both the 2.4 & 5 GHz radios are set to "Automatic." You would first change this to "Manual," and then, select the desired channel.
Oct 10, 2017 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Can i hook up 2 computers to the rca dcm425 without a wireless router
RCA DCM425 digital cable modems only have one Ethernet cable located in the back of the device. In order to have two computers connected at the same time you will need to have router. The router will connect to the Ethernet port on the back of the RCA modem and then you can have up to 4 computers connected directly to the router using Ethernet cables. If any of your computers are wifi compatible they will also be able to get online by using the wifi from the router.
Sep 29, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
1,204 people viewed this question
Top RCA Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
