Question about RCA DCW615R Wireless/Cable Modem
RCA Wireless Cable Modem DCW615R compatible with windows 7?
Is the RCA Wireless Cable Modem DCW615R compatible with windows 7, it was working wednesday afternoon, there was a windows 7 update and now the PC cannot connect to the internet due to a modem issue
Thanks in advance for any feedback
the son of the computer owner
Posted by dgs1123 on
Circe Denyer
  • 532 Answers
When I type in 192.168.0.1 it asks for a login where do i get that from
> where do I get that from
You ask your cable-modem company, if you acquired the cable-modem from them.
Or, if you purchased the cable-modem, then the ID/password were included in the packaging.
Nov 13, 2010 | RCA DCW615R Wireless/Cable Modem
How do I password protect my network using my mac with the rca DCW615R
You can protect you passsword using LoginTrap http://www.protemac.com/LoginTrap/.It’s really good program. Try)
Jun 26, 2010 | RCA DCW615R Wireless/Cable Modem
Trying to set password for RCA DCW615R router. Want to keep others from using it for their internet. How?
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 27, 2009 | RCA DCW615R Wireless/Cable Modem
I don't have cable but in order have the wireless cable do i need to have cable installed first?
Yes you certainly need a cable connection before you can use the wireless capabilities of the cable modem.
Without a cable connection the modem is useless.
Regards.
Sep 30, 2009 | RCA DCW615R Wireless/Cable Modem
How do I lock my RCA DCW615R router?
You Router supports either WEP or WPA Security. First thing to do is enable the security, it will become difficult to enter from other users.
IF your using a default gateway (192.168.x.x) which is your Router Address. You can enter by Internet Explorer to go inside the Firmware of your Router (http://192.168.0.1) then enter.
This is an example of firmware worksheet:
Please rate me.
Thank you.
Sep 04, 2009 | RCA DCW615R Wireless/Cable Modem
Cant use 2 laptops at same time
you need a router to connect 2 pc to one modem at the same time
Jun 15, 2009 | RCA DCW615R Wireless/Cable Modem
Wep key
new modem cant get wifi to connect
Aug 09, 2008 | RCA DCW615R Wireless/Cable Modem
The Rca DCW615R
You didn't say who your cable internet provider is, and many (or most, including Comcast) such providers require that the cable modem's MAC address be registered with their network. It's a security feature to prevent unauthorized (read: unpaid) users to access their network. The MAC address is usually found on a sticker at the bottom or rear of your modem. Write it down, then call your cable company's tech support the register it. It should work just fine after that.
802.11g upgrade
You can have comcast allow you to log in using the new firmware at 192.168.0.1. You will need the user name and password from them. This will alow you into the firmware so you can change settings, including the PCMCIA card.
Sep 07, 2006 | RCA DCW615R Wireless/Cable Modem
RCA DCW615R Wireless/Cable Modem Logo
458 people viewed this question
Top RCA Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
