Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
How do I open a port on the RCA modem dhg534 to allow me to do remote deskstop within my network?
Posted by jpiperipm on
ikkenom
    Brigadier General:
  • 10,406 Answers
> open a port on the RCA digital cable-modem
This device has no "ports" -- all the traffic goes right through out, unfiltered & unblocked.
Connect your computer directly to the Ethernet port on the cable-modem
Configure the Windows Firewall to "open" any port(s).
Posted on Jun 27, 2011
How do i make wi fi work on it?
Hello
Disconnect your modem from the wall socket it's plugged into.
Connect the Ethernet cable to the back of the modem. There is a clearly marked Ethernet port here. This port will appear to be an oversized telephone jack.
Connect the other end of the Ethernet cable to the Ethernet port on the back of the wireless router. This port will look exactly the same as the one on the rear of the modem.
Plug the broadband modem back up to the wall socket and wait for it to power on, initialize and detect its new connection to the wireless router.
Locate the manual that shipped with your wireless router. Find the URL, or web address, that is contained within the pages of this manual. This special web address is used to set up your router's network and security permissions. Also, be sure to locate the default password provided within the pages of the manual.
Enter the URL into your web browser and allow the page to load. When prompted, enter the password that you found within the instruction manual.
Begin setting up your new wireless network. You will be asked for an "SSID," which is just a moniker for your new network. This will be the name seen when the network is listed in an available network list. Choose whatever name you like.
Select a password for your new network. While encrypting your network is optional, it is highly recommended. Along with the password, choose "WPA" security encryption. "WEP" will also be an option but it is an older security protocol that is technologically inferior to WPA.
Click "Apply" to save your changes.
Click on the wireless icon on the right-hand side of the bottom toolbar on your PC's desktop. Select your network's SSID from the drop-down list.
Enter the password you chose for your network. You will now be connected to WiFi Internet on your PC desktop and free to browse the Web.
Oct 03, 2010 | Computers & Internet
How do i open ports on my rca thompson router
I would also love to know the answer to this I need to open my port to on the modem so I can use the network camera.
Aug 23, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
Jun 10, 2017 | D-Link Securicam Network DCS-950G Wireless...
Port forwarding tg782t to allow remote desktop
your firewall might have an Intrusion Detection System (IDS) which locks your network if programmed to detect unwanted ports. Work on your firewall first. hope this helps..
Aug 16, 2009 | Computers & Internet
Can't get NAT setting to Open for xbox 360. Won't connect to other users with open setting
The NAT is set to the actiontec modem/router so the next troubleshooting is to open the ports of the XBox ports 80, 3074, 53 TCP and 88, 3074, 53 UDP. To allow the XBox on the network using your modem/router.
Jun 27, 2009 | Actiontec (GT704WG) Router
DHG535-2 and LAN switch issue
It sounds like the LInksys that they replaced was also a router. A router will route packets to multiple pc's that are connected to it. The cable modem just sees the router as 1 pc. When you use a switch, the cable modem will see all of your PC's. and Comcast just allows 1 pc. You will need to buy a router to use more than 1 PC which will be cheaper than using Comcasts Home Networking service which will network up to 4 pcs
May 29, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
SECURITY CAMERA SYSTEMI
Have you setup a Virtual Server within the D-Link router? This should be on the ADVANCED tab in the D-Links Admin Configuration interface. Upon setup, the router should allow pass through of your request to the network connected device.
You will need the following in this configuration:
Name of device: SSC21WEB (or whatever the name of your device is)
IP Address: 192.168.0.101
Protocol Type: TCP
Public/Private Port: 10000 - 65535
Schedule: Always
Good Luck...
Oct 08, 2008 | Samsung SSC DVR Digital Video Recorder...
I am adding a new deskstop to my house, so a friend gave me his belkin router. i have been trying to set it up, but the problem is i have qwest choice internet and my modem is in my cable box in my master...
Wat u do is to just Connect ur Telephone wire to modem as usual and the output of modem has to be given to WAN port of ur router. your router must have atleast 2,3 LAN ports, take output from those ports and connect it to ur both desktop pc's...
Sep 05, 2008 | Belkin Computers & Internet
Remote access to my work desktop
Your modem is what connects you to the internet, your Mac airport is a router...One of the quirks about Apple's AirPort Base Stations is that they are routers, but not modems. As a quick refresher: a router enables you to create a network that connects various devices together (Macs, iPhones, iPads, hard drives, printers and so on); whereas a modem connects your network to the wider internet.
Feb 05, 2018 | Broadxent Computers & Internet
Bridge RCA Thomson DCM315R
Usually cable providers provide public ip directly to your company ( already bridged ). so no need to configure your modem to bridge.
- Connect the computer directly to the modem and if possible, let me know the ip address of your PC, So we can find the modem already bridged.
- If its already bridged, then Open the ports on your Router ( port number : 3389 for TCP ) or else you may try DMZ Host on your router to check whether it works.
Note:
DMZ ( Demilitarize Zone ) host which opens all ports on your network and shows ur computer to the outside Network which is not really secured one. but you can try it for testing purpose whether it let you to use remote desktop.
Hope this will help you
Sep 19, 2007 | RCA Cable Modem DCM315R (11603540)
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
476 people viewed this question
Top RCA Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
