Very time I try to take a picture my camera goes back and forth from the different settings. when it does take a picture the pictures turn out really fuzzy
The camera is stuck in picture review mode. Try sliding the mode switch back and forth a couple times, and leave it in camera mode to see if this corrects the problem.
I assume you have tried rotating the dial back and forth to try to clean the contacts when camera is off.
If this hasn't worked, try dropping some contact cleaner, available from radioshack or try alcohol first, with a toothpick under the edge of the dial when camera is on its back, at the same time rotating the dial back and forth. I haven't tried it, but the dial knob may pull off the camera if you can get a little pry under it.
If this doesn't work, consider getting a quote from a local camera shop, cause pana with be too expensive. Also, repairmen and those upgrading to the TZ5 sell very good TZ3's on ebay, and will buy yours the way it is. The difference you would pay for a sell and buy ebay will likely be less than a repair bill by a camera shop.
Try switching the macro off, if it is on. The macro is for close-up shots. When my mom uses her camera with the macro on, it gets really out-of-focus. I look like a flower.
try these two things i cant promise they will work
first turn on take hold of the lense and gently pull and twist you may hear it click dont force it then trun off and on again. this should fix the access and lense problem
then also try
Press Menu button togle across from REC Mode to setup togle down thrice from camera to setup 1 togle across into sub menu togle down from four times to Initialize togle across again to the sub-menu togle up from cancel to OK press center button to accept the OK choice Screen changes and so press okay again It should restart the camera Opening on the 'Clock Set' screen togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction. If it is working then don't forget to set your Clock.
Here as in some other posts, you can try to RESET the firmware in the menus. Go through the menus and find where it says something like reset all. What this does is to reset it back to factory settings. Then set the options you like, and then try the camera again.
Check the diff. modes for the picture taking. See if the flash can be turned off.
Hallo First, try to use different batteries. it can cause to long reaction times Second, try to buy a faster memory card, it usually help for the time it takes to upload and see the pictures on the screen about the blurry pictures are you using M or a different mode?
Firstly press the 'menu' button, then the up
button above the 'OK' as many times as needed, until you see the top
folders are highlighted.
Press
the right button near the 'OK' until you see the last folder
highlighted. You will know this is highlighted when you see the first
menu option that says 'Language'. The 3rd one down from that says
'Clear Settings'.
Press the down button under the 'OK' until 'Clear Settings' is highlighted, then press the 'OK' button.
Scroll up to your choice and press 'OK' to reset your Canon 400D back to default factory settings.
Now try - it could have fixed it. If not, keep turning the dial back and forth, and see if it jogs the camera's operating system. Try switching on and off. You should know, by the way, that the on/off switch doesn't really switch the power off - it tells the internal computer chips that you want the camera to switch off, and then the program closes it down enough to not respond until you either switch it on again, or take the battery out and re-insert it, when it will indicate a red light on the back of the camera to show the battery has made connection, then you switch on again; good luck - if not, phone Canon in your area
check the developed film if the sproket holes are intact.
check your camera without film.
(1) open the back, do it as if you were taking pictures with different apartures/shutter speeds. If you can see the light coming in from the lens (no matter how little or how fast), your shutter and aparture diaphram are good.
if not, send it for service.
(2) if yes, check that the winding sproket wheel turns when you advance film.
(3) if it goes freely, try it again with finger pressing the sproket wheel. if this stops the wheel to turn, it is the gear/shaft inside disengaged. send it for service, of course.
(4) if your camera has a button for multiple exposure, ensure that it can be turned on/off as you wish, or you do not pressed it unnoticed.
