Blown protection circuit at best. Blown power supply and IC's at worst. Send it to a service center for an estimate, educated guess without having it on a bench in front of me $150-200 repair. To test for the possibility that it's not the amp, disconnect speakers and turn power on. If it stays clean, no"protection", check your subs for a shorted voice coil. Hope this helps.
Hi yeahonda,
Your Kicker L7 Ohms may be too low for the MA Audio Mono block amp. The MA Audio Amp is probably 2 Ohm Stable. The kicker will either be 2 ohm or 4 ohm Dual voice coil. To eliminate the low ohms as a possible threat to causing the map to go into Protect, Wire the kicker Voice Coils in Series. This adds the ohms, so that you either have 4 or 8 ohms.
I am using the following codes to show wiring. VC1+ stands for the Kicker Subs Voice Coil #1 Postive post. AO+ is the MA audio Amp output positive.
AO+ to VC1+
VC1- to VC2+
VC2- to AO-
This shopuld give you 4 or 8 ohm depending on the 15" L7 setup. Crutchfield does not carry the Kicker L7 in 15" They do have the L5 in 15".
If you know how to read a Volt Ohm Meter, set it to OHMs 20 and measure across VC1+ to VC1- and you should see between 1.5 and 5 ohms.. Do the Same with VC2+ to VC2-. you should see the same voltage. Also read from the Voice coil metal housing to VC1+ , VC1-, VC2+, and VC2-. and you should not read any ohmage to the case. The meter should say OL, or -1.
Good luck.
