sandra, not being sarcastic but why keep the fridge open for ten minutes? It can cause other problems too. Try not to keep the fridge open for long after bulb change and see if it works. Good luck.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
·Close light cover and secure with screw removed in step 2.
I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
That button just turns the interior light on when you open the door and off when you close it. Could a light bulb be slightly unscrewed? Or perhaps the bulb cover is loose?
You got a bad ground connection somewhere.
You have a voltage drop,where you shouldn't have,and as a result the bulb is dim.
Check the bulb socket/connector and related wiring, to that head light
The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
if you checked the fuses, and they are all good most likely the plug popped out or is loose, or bulb burnt out if only one bulb., and you will have to remove some dashboard to get at it
Did you try tightening the light bulbs? Try changing them. Then, check the spring mechanisms in the side of the door - perhaps they are stuck shut (these are the clips or buttons that control the light). Maybe it is a problem with the alarm?
there is a tab in the bottom of the light socket that can get bent so that it wont touch the base of the new bulb. unplug your refrig and use a small screw driver and bend the tab back out a little bit so that it will contact the new bulb...
