SOURCE: no sound on dvd recording
S-video cable does not carry sound, you need to use audio cables as well (there should be an audio port near the S-video port on your camcorder)
SOURCE: Record DVDs frrom Cable box DVR
Buy a recorder that records both +/-R and double layer disks.
I haven't seen a Comcast dvr but you should connect it to the svideo out port of the dvr to the svideo in of the recorder and the audio out to the audio in. If the Comcast doesn't have svideo use the video ports instead
SOURCE: CONNNECTING THE DMR-EZ475V TO A TV, THEATRE SYSTEM AND CABLE BOX
Solution #2
posted on Feb 09, 2008
jdrrwoods
Rank: Wiz
Rating: 84%, 12 votes
http://www.altex.com/product_info.php?products_id=9207 here is a link to a audio / video switch box you need one of these make sure it has several audio video in and at least one audio/video out
hook all you rca cables up to the audio/video in from the cable box, tv, and dvd/vcr combo then out to the surround sound youll also need to get some rca cable splitters for the out so you can run it back to the audio/video in to the tv as well as the surround sound here is alink to what they look like
http://www.altex.com/product_info.php?cPath=344&products_id=6201
youll need thre of these of course when hooking it up dont pay attention to the color on these just the ones from the tv and surround sound and thats it your done it will all work if you want it to were you dont have to get up and push a button everytime most of them if you push all the buttons in at one time theyll stay like that
SOURCE: Trying to record off DVR
I feel sorry for anyone who bought this piece of junk.
Nothing but problems. Flashes in recordings when constrast and scenes change. Black and white picture when it goes nuts and very often distorted or NO sound forcing you to stop and resume. Subtitles start automatically on every disc you put in, very annoying. Sony DVD remotes don't work at all on this box, which is also frustrating if you have kids and the original remote is often missing.
I am embarrassed to own this. I misread the box thinking it had component inputs for recoding. Not HD I thought...but component is definitely acceptable. To my horror there was only composite (Yellow Red White inputs)!. It's purposely designed this way so you can't get good quality recordings. In other words whatever you connect to the YRW is going to come out VHS lousy quality on your nice set.
This is like buying a cassette player to record your CD collection. I copied a couple shows for the kids and the poor quality and strobing backgrounds were too much to stomach on my Sony HDTV. The HDMI upscaling did NOTHING to improve the picture quality. I try them both separately and then together and toggled between both inputs and while there were some color shifts there was no difference in detail. I have many years in Photoshop so I knew what I was looking for.
The upscaled image actually looked worse than the original.
The only GOOD thing about this recorder is that it has a decent laser. It plays scratched discs that I know hung up the old player and goes through the rough spots without a single skip.
It also plays DVDR's that only played on the computer before.
The Jpeg slide feature is not impressive and the times I've tried to show I was reluctant to make anyone wait around while I fumbled around with the clumsy controls.
There are some overseas Sony models that have built in digital tuner, hard drive AND dvd burner with HDMI input so you can record right off the cable or digital channel and store it and later burn to a DVD and not loose any quality.
By the time US models have any decent capability we will have moved on to some other format.
It's the same for DVD burners. The 8.5 GB disks are still +$3/ea. even though the burners have been out five years or more!
Buy yourself an HD recorder and standard DVD player.
Make sure you read the box a couple times since "near HD quality" is often touted since it's most likely Component In instead of HDMI In. Check outside of the US for the best boxes. Also keep in mind how much storage HQ you can hold. The early models only hold 30 Hrs.
SOURCE: direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
