Computers & Internet Logo
Posted on Oct 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bought a new computer and want to use usb 3g adapter on new computer. I think I need to install software, however there is no disk drive as it is a netbook
Anonymous
Level 2:
Scholar:
  • Expert 100 Answers
  • Posted on Oct 28, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
100
Questions
0
Helped
29667
Points
129
Dear johnls,
Try to copy the installation CD to a flashdisk the run the installation from flashdisk when you connect it via USB jack on your netbook.
Or try to connect the external Optic Drive (CD/DVD ROM), wait until the netbook complete the installation of your optic drive. Restart your netbook with external CD ROM connected via USB jack, then run the 3G installation from your External CD ROM.
GoodLuck!
Best regards,
bionic23
Iintend to change my sata hard drive to a SSD hard drive.How do I format before change
When you install Windows on your new SSD hard drive you can then transfer data from your old hard drive using an USB hard drive adapter or install the old hard drive into an USB hard drive adapter case and use it as an USB external hard drive after you have transferred your data to your laptop.
When you connect the USB hard drive adapter to the laptop, the laptop will see it as an external storage device, you can then open the various folders anf files and copy them to your new hard disk.
Hello Expert, I'm using WD1600BEVS that is my external hard drive. It has been working well with my laptop, but suddenly my laptop hasn't recognized it. I tried with other computers, but they didn't...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
I have used my hard drive twice, and then i went to plug it in and it keeps flashing and saying i need to reinstall the new usb. I think someone might have unplugged it with out doing it properly through...
* the USB cable
* the power-adapter
Hello, I just bought a Seagate Free Agent Go 1
* the USB cable
* the power-adapter
2answers
My external hard drive fell a few days back, it's hardly 6 months old. I bought it from gulf and have it's warranty card and all other related papers. Now if i try to connect to any system, the software...
Most of the time, "self-inflicted" damage is EXCLUDED from W.D.'s "warranty" for the drive.
So, it depends on your sense of "ethics" whether to file a warranty-claim.
* the USB cable
* the power-adapter
1helpful
2answers
Its totally not working, all pc cant detect it. i changed the wire already, re install the software. the model is WD10EADS. What I will do, can I recover the data? or Can i just use it again, if the...
* the USB cable
* the power-adapter
Disk spins ...then I hear a beep...icon does not show up
The hard disk or the adapter case maybe faulty.
To test the hard disk, remove it form the Iomega case and connect it to an USB hard disk adapter and plug it into a computer's USB port.
If this computer see it as an external hard drive and you can open the folders and files then the hard disk is OK, then the Iomega adapter case is faulty.
Then you need a new hard drive adapter case, it doesn't need to be an Iomega brand.
My fujitsu laptop recently had a new hard drive installed in it ,but i want to transfer the data i have on the old hard drive that was removed from laptop to my new hard drive. I bought the all in one...
The Coolmax adapter is an USB hard drive adapter that can connect various types hard drives to your computer. This is used for testing and and transferring data to and from hard drives connected to the computer via the computer's USB port.
This Coolmax USB hard disk adapter can connect a 2.5-, 3.5- and 5.25-inch IDE or SATA hard disk to a PC. The black adapter box connects the hard disk, while the secondary power plug/adapter powers the drive. In the case of smaller notebook or SATA disks, the power cable is plugged directly into the adapter (as opposed to straight into the IDE hard disk).
The red USB cable, meanwhile, can be used to power hard disks directly from the host PC's bus via another USB port.
Connect the hard drive to the adapter as detailed above, power up your computer and plug the Coolmax USB cable into the conputer's USB port. The computer will detect and see this as an external drive, most likely as a E drive (the next drive letter that is available). Click on this drive and open to open the folder/s where your data is stored then select the folder/s and/or data and copy them, then open the hard drive on the computer and paste the folder/s and/or files onto the new hard drive.
Wireless internet
The 3G mobile internet adapter is a small dongle that you need to plug into a computer.
The software setup is often automatic, and software will be installed by the dongle itself.
After installing you will need to pay for internet traffic, either with a contract and monthly fee, or with a pay as you go contract.
Fees vary depending on your country and on companies.
Here is an example of 3g adapter for UK MOBILE BROADBAND MODEM HUAWEI DONGLE 3G USB MODEM.
Better to buy adapter, sim card, and eventually cotract all from same company at a shop.
Can't get NEC Litepad to recognize new Toshiba 1.8" MK2004GAL
I've read on other web forums that the recover disk only works with the original drive partiions. There's a hidden partition on the original drive that the recover disk uses to install the OS (maybe other software too). You'll need to clone/copy the original disk partitions to the new hard drives and then you'll be able to use the recovery disk.
Grand Canyon Tech
Grand Canyon Tech
