SOURCE: Fisher and Paykel DEGX1 Electric Dryer Stays Warm
Yes, get a new element. The reason it's on all the time is because the element coils have broken and one of the coils is touching the canister that encloses it. This creates a direct short to ground. By the way, the element has 120 volts to it all the time. It will only HEAT when 240 is applied through the centrifugal switch of the motor. Your 120 volts is shorting to ground... not enough amps to trip the circuit breaker, but enough to glow the element.
SOURCE: dryer is not heating well
a heating element is not hard to change out, open the back of the dryer and locate the heating elemental unscrew the screws and replace it. Let me rephrase that the heating elements are usually not hard to change out. I pretty sure if you no where the heating element is you will have no problem with. let me know how it goes for you.
SOURCE: lint assembly-Fisher and Paykel DEGX1
Pretty easy on the lint assy;
Remove the lint cup;
Find screw (5) in a recess at the bottom of the lint cup area;
This will allow removal of the perforated lint surround, and the 'lint scraper'; Also will expose the moisture sensor (3) hanging off wires at the bottom of the assy;
At the bottom of the surround there is another recessed phillips screw; remove this, then twist the surround (14) counter-clockwise about 1/2" and remove to expose the filter (13).
<img src="http://img50.imageshack.us/img50/9130/outlectductsh4.jpg" alt="FP Dryer Lint parts"/><br/>
Not sure on the reset- I do know the top swivels up after removing the two screw caps and screws at the front of the unit on either side. This exposes the underside of the control panel; there are screws at the back of the control panel also.
SOURCE: Fisher & paykel Dryer
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Check
to see whether there's power getting to the dryer. Is it plugged in? If
you plug something else into the outlet, does it work? If not, check
for a blown fuse or tripped circuit breaker.
Door switch
If
the door switch or the door-switch actuator is defective, the dryer
won't work and you need to replace the failed component. The switch is
inside the dryer main housing near the door frame. Sometimes you need
to raise or open the top or front of the dryer to reach the switch.
Thermal fuse
On many dryers, there's a thermal fuse (a heat-sensitive fuse
that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an
inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your
dryer either just stops heating, or it doesn't work at all. Be sure to
inspect the venting/heating system before replacing the fuse to put the
dryer back into operation. (You can't re-set this type of fuse.)
Wiring
Often
the main wiring connection from the house, at the dryer, burns and the
connection breaks. In this has happened to your dryer, you need to
replace the power cord and the terminal block inside the dryer to which
the wire is attached.
Drying is too slow
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour or is not drying properly, check these.
Vent
Frequently
there's an obstruction in the vent duct from the dryer to the outside
of the house. For the dryer to heat properly, the duct must be clean
and clear of lint or any other substance.
Heating element
Your
dryer's heating element may be partially burned out. If it is, your
dryer still heats, but at such a low temperature that it takes three or
four times as long to dry the clothes. If the element is partially
burned out, replace it.
Internal ductwork
Your
dryer has some internal ductwork. If it gets clogged, your dryer can't
dry properly. In most dryers, to get to the internal ductwork to clear
the clog, you have to substantially disassemble the dryer. A quick way
to check for internal clogs is to remove the lint filter and use a
flashlight to inspect the inside of the duct. If it looks clogged and
you can't clear it using your vacuum, contact a qualified appliance
repair technician.
Cycling thermostat
Although
this isn't a common problem, one of the thermostats that controls the
temperature in your dryer may break and cause the dryer to heat poorly.
If so, you need to replace it. The thermostat is usually a small,
round, black device mounted to an oblong steel plate. The plate is
mounted to the internal ductwork with two screws.
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: dryer takes MUCH longer to dry clothes than it should
Is the hose crunched down at all in the back
(vent hose)
