As shown in the picture double check the vibration flexible wire connecting to the center, you cannot see it on your naked eyes, use tester to prove the connection, use soldering iron to reattached the broken circuit, be responsible for the connection, put in mind that it is vibrating too heavy...
Sounds like you have completely blown the speaker, simple test is to push on the cone and see if theirs resistance and noise.
if there's strange noises its buggered.
another way is to put a 1.5 volt battery across the terminals on the speaker is there's no sound your up for a new speaker
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
