LG 42lc2d found u502 in power supply bad. The whole front blew off of the chip and i cannot seem to find the part number in the service manual. I am tossed on replacing the power supply board or if there might be something else wrong that will blow up the new power supply. A satellite guy came out and put in a new box. I am pretty sure he was messing with the hdmi cable with the tv on but about an hour later the tv just went dead.
The Number IC is ICE3B1565J MAX 12V 3.3V
Regards!
Vagner CostaWave Corporate Softwarehttp://www.wavecorporate.com
You won't find a part number for this ic. These boards were made to be replaced as one piece. A new board should do the trick. If you can try to check for a short to ground. Most of the plugs on the board have voltages labeled. If there is a dead short you will see it with an ohm meter.
tv is dead
