2000 Saturn SC Logo
Posted on Oct 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rear door lock on 2000 saturn broken. Stuck in
Rear door lock on 2000 saturn broken. Stuck in locked position so door wont shut.
Anonymous
Level 3:
  • Master 543 Answers
  • Posted on Oct 13, 2009
Anonymous
Master
Level 3:
Answers
543
Questions
0
Helped
274420
Points
1601
Your gonna have to remove the inner dor panel and replace the latch lock assembly
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
718
Points
How much is a latch lock assembly for a 2000 saturn sc?
Cannot open rear drivers side door from outside or inside. door panel is off, door is closed. child lock is on. tried pulling cable, wont move. tried lifting up the child lock with a thin blade
Sounds like the lock mechanism is stuck on the locked position. Since you didn't specify make and model this is a best guess. Make sure the lock is in the unlock position and try manipulating the rod connected to the outside handle (since child lock is on the inside handle won't work)
2003 Saturn view rear hatch will not open what do I do how to fix that
As the same with a trunk lock a foriegn object can can get in between the lock and latch. Lucky for you and even better if the back seats folds down you have an easier access. Now crawl into the rear taking with you a 2 screw drivers,pliers and needle nose pliers. look for something stuck in between the door and the jam if so try to pull it out. If you don't see anything try this, get one person to put key in door and another to push the electric lock while you push on door. If that doesn't work you'll have to rake the door panel apart be carefull not to break the plastic after 11 years it does become fragile. once inside the door try to release it manually the cable may have broken
Rover75 52plate door stuck
52 plate ?? is this a sit up and beg type rover 75 ,you know the big thing with the bench seat and handbrake between the door and seat?
2000 hyundai sonata passenger door lock stuck in locked position
If your talking about the teeth/latch that actually engage around the pin to hold the door closed and not the lock you puhs down to lock it. all you have to do is get a screwdriver or anything small and strong you can stick in it and pull the tooth back into the "open" position. You might have to pull the handle out like your opening the door normally while you do this.
2005 Saturn Relay power doors don't work rear hatch locked shut...help
its alot going on if all that started happening at one time check the bcm. body control module.
Security light flashing on the dash and the electric door locks won't unlock from the inside of the car but will lock.
The door lock solenoid is stuck in the lock position,Do you relly need the convient of a door lock and unlock how many cars fight the owner and wont let them in. time to get a door lock solenoid.
1helpful
My 2005 Yukon Left rear door latch is stuck. I can't the door to shut.
if the latch is in the lock position insert a pen into it hold the handle open and pop it out
Top Saturn Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Saturn Expert? Answer questions, earn points and help others
