2008 Suzuki GSX-R 600 Logo
Posted on Oct 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Komota wont stay hold charge if the key stays
My Komota wont hold charge if the key stays in the ignition it loses charge asap whats up with that?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 278 Answers
  • Posted on Oct 13, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
278
Questions
0
Helped
109306
Points
741
Check for a intermittent short in the ignition
1999 olds aurora wont run unless hold key in a certain position
sounds like the ignition switch has an internal problem and requires changing.
Immobilizer light stays on engine won't start
Make sure the key isn't on a keyring, and if you have a spare key try holding it against the ignition barrel whilst trying to start the car. Failing that, it's an auto electrician job. China OBD2 car diagnostic tools wholesale on CareUCar
2answers
My envoy wont start turn key and everything works but wont start
What ????? i try to sterted manuely and it start but turn off the light stays on with the ignition. What light stays on ????
i try to sterted manuely ???? I try to start it manually !!!!!!! You need to take your vehicle to a qualified professional technicia .
Chevy cavalier had new ignition put in and was working fine. A few months later the key would not stay in run position after starting. I had to hold key and slowly let go to kkeep car running. Now car wont...
when you turn the ignition key it activate a metal rod to ignition switch on top of column steering
this switch is adjustable by loosing the two bolts and nuts
look if you bend that rod could be the problem
hope it helps
Wont stay running with out holding key
Have no idea what kind of machine you are talking about but it sounds lie your Ignition switch is bad Or the 'Run' wire coming off the ignition switch is not sending voltage to the Coil
Sep 28, 2013 • Garden
1helpful
My car just stop running i tried to restart it and it would not stay started
try the ignition switch.. i am not sure try turning the key and keeping it in the turn over position... if it runs it is the ignition switch probably.. it means it is running of your starter.. you will have to hold the key there tho.. because it wont stay started if you dont hold it in the turn over... it can also mean key and tumbler... do you have gas in it??
Ignition won't stay in running position.
You are gonna need a New Ignition. Will solve this Problem.
2helpful
My car wont stay running
Does the engine die as soon as you release the key, or does it run for a couple of seconds after you release the key and then die? If it dies as soon as you release the key, try holding the key for a few seconds and see if it will stay running as long as you are holding the key (the starter will make a grinding sound while holding the key but won't hurt anything). If it stays running while you hold the key then dies when you release it, that indicates that the ignition switch is bad.
Top Suzuki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a Suzuki Expert? Answer questions, earn points and help others
