Water Heaters Logo
Posted on Oct 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bled radiator and now boiler is losing pressure
I bled one of my radiators and now my boiler is losing pressure and the pilot light keeps going out. when i put the central heating on the boiler works and i can get hot water too but if i turn the central heating off the pilot light just goes out and i can't get hot water.
Help!!!
Anonymous
Level 2:
Champion:
  • Expert 248 Answers
  • Posted on Oct 11, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
248
Questions
0
Helped
130102
Points
317
If your boiler is a combi re-pressurise locate filling loop and refere to manual
Vokera boiler problems
need to change thermostat and a thermocouple
I have a Worcester Bosch HE system boiler. I am not getting any heating or hot water.The burner ( pilot light) is not on and the pressure gauge is on 0 bar. The boiler is about 7 years old. My decorator...
If a radiator was taken out and put back in I feel you have air built up in your system. There should; be an air relief valve on each radiator. Get your furnace up to heat and open the valve on each radiator till all the air is out of the lines. If there is air in the system there will be no heat. You do this after the heat is on. As far as the pilot not coming on you could have a bad igniter which may need replacing to get heat.
Vaillant boiler ECO Max 824E F 20 error
Did you bleed the air from the pump ? Sounds like a air lock
Hi wanting to know is it dangerous to keep filling the preshireb up & is it dangerous to do this when the radiators warning up,.... had a bit of drips on the raditor pipes just bled them'' :)...
Are you saying the 3/4 inch valve is dripping and you need to keep topping up the water to maintain the pressure?
If you do this it is "safe" but you will introduce more oxygen in the system with the fresh water.
This oxygen will corrode the radiators and possiblty the boiler heat exchanger depending on how much water you are introducing.
Change the Pressure reflief valve. This is a £10/$ 10 part and will save your system in the long run.
3helpful
2answers
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
6helpful
Flashing red light on Worcester 24i junior combi boiler
Pressure is ok? at 1 bar or above
I think on this one there should be a reset button [red] on the left hand top of the casing - or lower the control panel [ phillips screw on each side] and the button is on the left of the base plate. Press this and try the heating.or hot tap
P.S. if you're on a prepayment meter check you have gas.
Very Hot water coming out of overflow pipe
Is your boiler heating your domestic hot water if so i would turn water off to water maker and see if your boiler pressure stays down below 20 psi. If so water maker is bad. The other thing that could cause this problem would be the boiler pump is out.
1helpful
Boiler keeps losing pressure when the heatings off
Hi Leehardcast,
Yes the problems are related. The system is low on water. So now instead of water you have air in radiators which is easily compressed when it heats up. Then pressure loss when it cools down.
Add some water to your system until you have 15lb pressure and bleed out upstairs radiators at the same time.
Please rate this response and Good luck, Phil
4helpful
How to re pressurisecentral heating system
Hi tiger650,
I'm Harvey the Master Plumber.
Your problem is: The Alpha SY24 boiler has stopped working. The pressure gauge has dropped, you need to know how to re pressurise the system once the radiators have been bled
Every hydronic heating system is required to have a presure regulator. Most guys call it a feeder valve. Every one I've installed or worked on had one. It's job is to keep the water pressure constant by adding water when you release some air without over filling the system. Sounds like it's not working. Some types can be serviced, others cannont so you may have to replace it. If you're not sure what to do it might be prudent to check the Repair Directory for a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Top Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Water Heater Expert? Answer questions, earn points and help others
