Cars & Trucks Logo
Posted on Oct 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2000 Toyota Solara with 27,000 miles on it. I have been having a steering wheel vibration problem at 65 mph. The vibration is so bad that I have to pull over and stop the car completely. If I put my foot on the brakes, I can feel the vibration in the brake pedal. If I come to a complete stop, I can start driving again and the steering wheel vibration problem doesn?t occur again. The vibration doesn?t start if I drive over a bump in the road it start even when driving on a smooth road. The vibration problem started after I had the brake?s master cylinder and boosters replaced because I was having a problem with noisy brakes and the pedal would relaxed and go to the floor at times. Trying to resolve the vibration problem I replaced an almost new set of tires and had the tires balanced at Goodyear and at the Toyota dealer. I went to another repair shop and they replaced the front rotors and brake pads. After they test drove the car, the wheels were smoking so they replaced the front calipers and brake line hoses. After that the vibration was not as bad as it was previously, but there is still some vibration at 65 mph, and it only stops if I bring the car to a complete stop before taking off again. Usually when I start driving again the steering wheel vibration doesn?t start again. I would think if it was the rotors, that the vibration would be all the time and not just intermittent?
Anonymous
Level 2:
  • Expert 146 Answers
  • Posted on Oct 07, 2009
Anonymous
Expert
Level 2:
Answers
146
Questions
0
Helped
64431
Points
437
If it were the rotors it only happens when braking take in have them turn rotors see what happens good luck
Fix for cadillac deville 2000-2003 vibration between 65-70 mph
Have your Mechanic check the steering tie rod bushings, and linkage. Sometimes it's just an adjustment to the steering box play(located at the end of the steering wheel shaft), - easy to fix.
Vibration at 70 MPH.
Warped or out-of balance brake rotor? Also keep in mind that loose rear differential trailing arms that allow the rear differential to squirm around can also cause steering wheel shake.
I have a 2007 crewcab tundra 4.7 two wheel drive, i have steering vibration at 65 plus mph and when i tow a small boat the entire vehicle vibrates
maybe a bent rim or a tire out of ballance ckeck the outside for a clener spot the anywhere else that could be where a wheel weight was sitting and has slung off
3answers
Vibration in the steering wheel on a 4wd truck
I just had the same issue with a 1999 2500HD and the vibration got worse above 50 mph. Problem was resolved with a new driveshaft. Old one (aluminum) was badly out of true and the problem didn't really occur until I had the U joints changed - then bent driveshaft vibration was noticeable. New driveshaft resolved issue.
2helpful
3answers
Car shaking and vibrating at 55 mph. and does it again at 65-70.
Hi:
Since your BMW 540 series is a rear wheel drive car, a common cause of that sort of vibration is often the U joints on your drive shaft. The vibration often only shows up and certain speeds.
It isn't a particularly expensive repair, but is something to have checked out!
2000 Frontier w/ 190,000 miles. Vibration Problem
check cab to chasis mounting rubbers.
can remove one or two bolts and see if change in vibration
5helpful
3answers
Vibrating proplem
Your car has front disc brakes, the disc's are running out of true, as u apply the brake this causes the steering wheel to shake, the higher the speed the more u feel this, the solution is to have the front brake disc's machined true again on a brake lathe or if they are to thin replace them.
How many miles or years for a power steering flush
i have owned a lot of cars and never needed a power steering flush
that is just another come ON
Steering wheel vibrations - '05 Sienna
that happend to me in my eclipse you just need to get them aligned past 60mph and they will be fine.
1helpful
Noise (vibration) when turning right
That sounds like a left front wheel bearing gone bad My friend.. turning right transfers weight to the left side and it probably has a roar similar to a turbo fan jet.. Try it and lemmie know.. thank you
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
