Contributor
- Posted on Jan 28, 2023
Re: Masterlink ML 9600 playback of a song previously...
The Masterlink ML 9600 is a professional digital audio recording and mastering system, so there are a few potential causes for this issue:
- Hard drive failure: If the hard drive on the ML 9600 is failing, it can cause issues with playback, including distorted or "drill-like" sounds.
- File corruption: If the file that you recorded and saved on the ML 9600's hard drive becomes corrupted, it can cause issues with playback.
- Firmware issue: If the firmware of the ML 9600 is not up to date, it could cause problems with the playback, especially when it comes to filing compatibility.
- Interference or electronic noise: If there is any kind of electronic noise or interference in the area, it could also cause playback issues, including distorted or "drill-like" sounds.
- Problem with the analog or digital output stages of the ML 9600.
It would be best to check the hard drive, ensure that the firmware is up to date, and verify that the file is not corrupted, and then check with the manufacturer for further assistance. If the problem persists, it may be necessary to have the unit serviced by a professional technician.
