Windows 10
A write-protected flash drive is a device that has been locked to prevent any changes or modifications to its contents. To reformat a write-protected flash drive, you will need to remove the write protection before proceeding with the reformatting process. Here are a few steps you can try:
Note: Be aware that reformatting will erase all the data on the flash drive, make sure you have a backup of the important data before proceeding with the reformatting process.
Unfortunately, you can NOT access your user data and applications on the device without a password.
If you think you are entering the correct password, ensure that CAPS lock or NUM lock is not turned on. You should try to type your password in another application (like word or email) to ensure that it is being entered correctly. This can help you see if CAPS lock, NUM lock, or a sticky key is causing the password to actually be entered incorrectly.
Password attempts
There's a set number of attempts before U3 locks your device and you have to reformat it.
Reformatting will delete all files and applications on the flash drive.
Password hint
If you set a hint when you enabled the password protection, click Hint in the log in window to display the hint you entered. If you did not set a hint or still can not remember your password you will have to reformat the drive.
It is recommended to keep a backup of all the data on your U3 device on your PC for safe keeping.
