Master
- Posted on Feb 26, 2023
Re: when I push the start button, the light blinks but...
If the start button blinks and the dryer does not start, it's possible that the pause button may be stuck. Here are some steps to try and resolve the issue:
- Unplug the dryer: Safety first! Unplug the dryer from the power source before doing any troubleshooting.
- Check the pause button: Make sure the pause button is not stuck or jammed in any way. Press and release the button several times to see if that helps.
- Check the door switch: If the pause button is not the issue, check the door switch. Open and close the door several times to ensure that the switch is functioning properly.
- Check the circuit breaker: Check your home's circuit breaker to ensure that the dryer is getting power. If the circuit breaker has tripped, reset it.
- Call for service: If you have tried all of these steps and the dryer still will not start, it may be time to call for service. A technician will be able to diagnose the issue and provide a solution.
Remember to always put your safety first and unplug the dryer from the power source before performing any troubleshooting.
