Televison & Video Logo
A
Anonymous Posted on Oct 25, 2022
Is a Sony 32 Inch LED TV (KDL-32EX650) main board compatible with KDL-40ex650 please?
ADMIN Andrew
Level 3:
Top Expert:
  • Sony Master 66,980 Answers
  • Posted on Oct 25, 2022
ADMIN Andrew
Sony Master
Level 3:
Top Expert:
Answers
66980
Questions
Helped
5090488
Points
379943
Sony Bravia KDL-40EX650 TV dimming.
Generally picture issues are from timing board and associated cables in and out
Sony Bravia KDL-40EX500. Plugged in power and no backlight. No pic no sound. Could it be the power board or inverter board? How can I test these boards? Thanks.
SELF DIAGNOSIS FUNCTION
The units in this manual contain a self-diagnostic function. If an error occurs, the STANDBY LED will automatically begin to fl ash. The number
of times the LED fl ashes translates to a probable source of the problem. A defi nition of the STANDBY LED fl ash indicators is listed in the
instruction manual for the user's knowledge and reference. If an error symptom cannot be reproduced, the remote commander can be used to
review the failure occurrence data stored in memory to reveal past problems and how often these problems occur.
DIAGNOSTIC TEST INDICATORS
When an error occurs, the STANDBY LED will fl ash a set number of times to indicate the possible cause of the problem. If there is more than
one error, the LED will identify the fi rst of the problem areas.
Result for all of the following diagnostic items are displayed on screen.
If the screen displays a "0", no error has occurred .
Diagnostic Item
Description
Number of times Standby
LED blinks Possible Location
Main Power Error 2 G2HE/GD2 (Power) Board
Audio Error 3 A (Main) Board
Balancer 4
LCD Panel
Inverter Board (ETC-Inverter MT Board) for 32" & 40" Models
TCON Error
5
LCD Panel
TCON Control MT Board
HFR Error 5 LCD Panel
Backlight Error 6
LCD Panel
Temperature Error 7 A (Main) Board
This should help you narrow it down. I am also attaching the service manual for you. https://files.acrobat.com/a/preview/16a56e45-a439-48bc-8770-21638f2bab68
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Red lightblinkering not turned on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
My sony bravia tv keeps shutting off
in this case you tv main board is defective because this is a temperate error please replace main board
When turning on my bravia 32 is all black and then lines in color appear and then black again
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sony KDL-V32XBR2 - no picture, no sound...I'm pretty sure the hdmi input port is damaged...is it worth it to repair/replace? and can I do it myself?
Yes ,you should replace the main board ,because you can'nt repair HDMI interface.
Abctay.com Wholesale tv parts,include TV power supply board, logic board, TV LED screen
Sony 32" LCD TV KDL-32M3000. No picture, LED will
What does it do if you unhook the flat cables going from the tcon to the panel, does the blinking go away and do you have sound then?
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
