Expert
- Posted on Mar 09, 2023
Re: I have an bosch exxcel verio 7speed perfect washing...
The suds sign on your Bosch Exxcel Vario 7 Speed Perfect washing machine indicates that there is too much foam in the wash. This can be caused by using too much detergent or using the wrong type of detergent. Here are some steps you can take to try to resolve the issue:
- Reduce the amount of detergent: Check the detergent packaging for the recommended amount of detergent to use and reduce the amount if necessary. Overloading the machine with detergent can cause too much foam to be produced.
- Use the right detergent: Make sure you are using a detergent that is designed for use in front-loading washing machines. Using the wrong type of detergent can cause excess foaming.
- Run a rinse cycle: Run a rinse cycle without adding any detergent to help clear out any excess suds.
- Check the detergent dispenser: Make sure the detergent dispenser is clean and free from any residue or build-up that could cause excess suds.
If the problem persists, it is possible that there is a problem with the pressure switch or the control module of the machine. In this case, it is recommended to contact a qualified technician to diagnose and repair the issue.
