I have a Kariba washer dryer combo WD802. Taking water slowly.
Turn off the water at the stop tap near the machine.
Set the machine to a program and press start, and then turn the machine off. This is purely to relieve pressure in the pipes.
Remove the hoses from the back of the machine and in the threaded part of the machine you will see a wire gauze strainer. This is probably blocked with lime scale and debris. Remove it and clean it with a brush under running water. If you can see limescale in it, soak in white vinegar for a few hours.
Now you need to prove that the water supply is good. If you have a laundry sink next to it, use that, or if not get a large bucket, the bigger the better, in fact a dustbin is the best size! Have someone hold the bucket and hose whilst someone else turns the water on. You should get lots of water.
Put the strainers back in, reconnect the hose and check for leaks. Also note that hoses should be changed every 10 years and should have a date on them. Now would be a good time to change them, and you may as well get new strainers.
https://www.google.com/search?q=Kariba+washer+dryer+combo+WD802
