SOURCE: I have a Curtis 24
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
SOURCE: When setting up a new
you need to select cable from off your remote and run the auto scan.even if it says you does not need to run auto scan still run the auto scan.good luck.
SOURCE: Will not set tv channel to 3...keeps telling me to please run channel auto scan
You can do it manaly.
SOURCE: no pic please run channel auto scan
my problem turned out to be a wrong input. 2 days of frustration
I really did think i had it set right so i double checked.
Hi Patty Fisher, Got a make and model number on the TV ?
The ROKU should be ok its coming in to the tv most likely on a HDMI port.
The Auto scan is referring to the tv channels. In the TV menu (guessing as I don't have model or make ) look for channel setup and there should be an auto setup option you need to run.
