SOURCE: MTC2 2400 Series Desktop
if therte is a switch on the back of your pc on the power supply check to maske sure it is switched on. if that all checks out try directly connecting the cable to the wall socket if your arnt already doing that. if that doesnt workout check to see of your surge protector if you have one and see if the switch is on. if all those options fail you are going to have to go into the pc case. check the cpu power cables. they are a 4 pin connector in a square shape usually and placed next to a big fan wit a heat sink on the mother board. give that a riggle and push to make sure it is connected. plug the power back in and see if it works. if the problem still isnt solved you can if you know how too check your power button connection on the motherboard and give it a little riggle. if that all still fails then i think your power supply is no good.
SOURCE: Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
SOURCE: My wii won't turn on. It's plugged into an outlet
Unplug the Wii for at least 5 minutes.
This forces a Wii "RESET".
Then plug it back in and it should work.
SOURCE: I just bought the eclipse
There are two things that come to mind, the new battery is not holding a charge, or there is a problem with MP3 players circuitry. Remove the battery for 60 seconds and re-seat it back in place hopefully this will reset the processor ic, if this fails take it back because there is nothing more that can be done since the item is under warranty.
SOURCE: how do you download freemusic to my eclipse cld 4gb mp3 player
First you download the music from MP3 music sites to your computer, then connect the USB cable to your player and plug the USB cable into the USB port of your computer. The computer will see the MP3 player as an external storage device then copy the MP3 music files from your computer to the MP3 player.
