Question about Eclipse TCH828 Digital Media Player
How do i download music onto my eclipse? - Eclipse TCH828 Digital Media Player
Posted by julianreese8 on
Jalal Sordo
  • Eclipse Master
  • 1,800 Answers
Hello.
Welcome To Fixya Community
There you go :
  1. Connect the MP3 player to a working USB port.
  2. When the unit is connected to your computer, it will create a gray and green icon in the system tray (lower right hand corner of your desktop). The icon will be called safely remove hardware.
  3. Go to the “My Computer” section of your computer. In there you will find a section called “devices
    with removable storage”
4. Locate the drive created by the unit, generally just called Removable Disk, with a letter in Parenthesis. Drive letters vary depending on your system configuration.
5. Open the drive by either double left clicking on the drive itself, or by right clicking to open the option menu then left click on the desired drive.
6. Locate the music stored on your computer. Generally this is stored in the “My Music” folder of your computer.
NOTE: if you are unable to locate the music on your computer, click on start,search, files and folders, then search for “*.MP3, *.WMA”.
7. Once you have located the song files, you can right click on the song itself, and select “copy”.Open the removable disk drive, right click on in the empty space, and select Paste. This will transfer the song on to your MP3 player.
8. Repeat step 7 for as many songs as you want to copy on to the unit.
Additional Help:
Eclipse TCH828 Manual Guide
Thank You
Let Me Know If You Need Any Further Info
Best Regards
Posted on Nov 07, 2009
  • 1 more comment
  • daria
    daria Jun 17, 2016
    This is the best advice. I tried this and it worked. I love you!!! No I can listen to music and when it freezes, i would know what to do. Thanks for the advice.
  • daria
    daria Jun 17, 2016
    yeah,listen to this advice and use it
  • hannah
    hannah Jul 14, 2018
    how to download music
jose
    New Friend:
  • 3 Answers
I want to download music in my eclipse
Posted on Dec 29, 2012
Anonymous
    New Friend:
I tried this and it didnt work.
Posted on Dec 25, 2009
jennifer
    New Friend:
How can i download music in my new mp3 will you help.ok!
Posted on May 13, 2013
1 Related Answer
Anonymous
SOURCE: Cannot download movies onto my Eclipse MP3 player
how do i format a movie it is on my mp3 player but when i try to play it says format error
Posted on Feb 26, 2010
How do I download music from windows media to the mp3?
make a playlist in Win Media player and sync it to your Mp3 player or you can drag and drop music onto it directly but that is a bit more complicated unless you know wehre the music or media folder is on the device
Jan 22, 2016 | Eclipse Fit Clip Plus 8GB* MP3 Player
What do I do to Eclipse fix mp3 when it diplays "Disk Error!" upon attempting to play music?
Presumably the error is caused by a hard disk drive? In which case the hard disk will need to be checked. If there are options to do this use them. Otherwise the drive might need to be replaced.
If you bypassed the normal way of putting music onto the drive, then it might have corrupted the drive.
If there is an option to reformat the drive that might work. Or if there is a factory reset, that might correct it.
If you have music stored on the drive, which is not found anywhere else, then I think it will have been lost for good.
May 27, 2017 | Eclipse Audio Players & Recorders
Downloading music
If you have any music discs, download them onto the computer and make sure they are MP3 files, if they are WMA it won't work, if they are WMA, you can convert them.
Jan 04, 2014 | Eclipse 180g2 4gb mp3 music/vid
DOWNLOAD MUSIC
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Jan 22, 2013 | Eclipse 180g2 4gb Mp3 Music/vid - 180 G2...
Downloaded music in folder, how do I get it to play?
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player. For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Jul 20, 2011 | Eclipse CLD2 MP3 Player
When i download music onto the player it just says no files
plug the device into a computer, access the device through my computer and inside of the device make a folder called "MUSIC" then drag and drop all of your music into there. That should fix your problem.
If this helped please rate
Thanks Robert
Jul 08, 2011 | Eclipse CLD2 MP3 Player
Two questions: How do I create folders on the Eclipse mp3 player? How do I download audio books to the Eclipse and keep the books in folders?
Connect your MP3 player with the supplied USB cable to your computer. The computer will detect this as an external storage device, then click on this device and go to the music folder. You can create a new folder/s inside the music folder and you can copy your mp3 audio files into the folders you have created.
You most likely need to convert your audio book files into mp3 files.
MP3 players can only play music files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
May 19, 2011 | Audio Players & Recorders
I download audio cds onto my player and it plays for 2 seconds and then stops.
Mar 19, 2011 | Eclipse CLD2 MP3 Player
Feb 09, 2010 | Samsung YP-T10JAW MP3 Player
Eclipse TCH828  Digital Media Player Logo
28,080 people viewed this question
Top Eclipse Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
john h
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
