Question about Eclipse CLD2 MP3 Player
Need driver for eclipse cld mp3 media player - Eclipse CLD2 MP3 Player
Donald
    New Friend:
Hi
You can find it here: http://tinyurl.com/kb7qkwz. I've used it many times before for updating drivers
Posted on Jan 04, 2015
5 Related Answers
John Cunningham
  • 6771 Answers
SOURCE: I just bought the eclipse
There are two things that come to mind, the new battery is not holding a charge, or there is a problem with MP3 players circuitry. Remove the battery for 60 seconds and re-seat it back in place hopefully this will reset the processor ic, if this fails take it back because there is nothing more that can be done since the item is under warranty.
Posted on Mar 01, 2011
Anonymous
SOURCE: I have 2 Eclipse CLD MP3 players and I cannot get
you just need to hit the "VOL" button once, which will light up the # of the volume setting (18 is factory set). then you toggle the left or right arrows to either decrease or increase the volume # to the desired setting. i think the highest is 32.
Posted on Jan 02, 2010
Anonymous
  • 6 Answers
SOURCE: how do i delete songs off of the eclipse cld mp3 player?
you hook up your mp3 player up to your computer, go to window media player, go to portable device, and right click whatever song you want to delete( :
Posted on Feb 08, 2010
Anonymous
SOURCE: I have downloaded music into
You have to follow both steps on the instruction manual. When you first plug it into your computer it prompts you to name it. Then sync the music files off of Windows Media player..then you must do the second part where it explains about copying and pasting the music to it..this link opens the pdf manual that explains it just like the directions that came with it. http://www.eclipsemp3.com/CLD2manual.pdf
I think people are getting confused and thinking that step is only suppose to be used if they can't sync it ..but you actually have to do that part too or the files won't go onto the MP3 player.
Posted on Feb 14, 2011
Tesseract
  • 3 Answers
SOURCE: No matter what I do my MP3 player Eclipse CLD
Even the above solution did not work for me, but once I got rid of ALL folders, even the highest level, and dropped the tracks directly into the root directory of the player (alongside the free tracks that come pre-loaded) it worked fine. This means if you are using WMP to load songs, you will have to manually undo the nested folder hierarchy WMP creates.
Posted on Sep 26, 2011
Eclipse CLD player
Please express your problem in more detail.
Oct 26, 2013 | Eclipse CLD2 MP3 Player
My Eclipse CLD shows its playing music but there is no sound even though the volume is all the way up
the problem could be with the headphones or the jack on the mp3 player itself
Sep 13, 2013 | Eclipse CLD2 MP3 Player
Is there a way to delete the music on my Eclipse CLD 4GB MP3 player
When you connect your player to the computer and you copied the music files from your computer to your player. You can also select the music files on your player by right clicking on the music file and then click on Delete.
Apr 15, 2013 | Mach Speed Trio Eclipse 4gb Cld Mp3 Silver
Eclipse cld won't turn on
what i just did was made sure it recognized it on my computer and quickly unpluged it and put it in my xbox
Mar 12, 2012 | Eclipse CLD2 MP3 Player
User manual for eclipse cld 4GB mp3 player
i download a bunch of songs and i can only heard a few of them..any solutions??
Jan 02, 2012 | Eclipse Audio Players & Recorders
How do i delete songs off of the eclipse cld mp3 player?
Feb 07, 2010 | Eclipse CLD2 MP3 Player
I brought an Eclipse CLD MP3 and when i charge it, it says it's finish so i take it out and but it back in then chargeres another hour....is it charged all the way?
I bought a Eclipse CLD MP3 Player, the music does not sound the same as downloaded. You can only hear the background vocals, not the lead singer. How do you fix this or is the MP3 ****?
Nov 07, 2009 | Audio Players & Recorders
Eclipse CLD2 MP3 Player Logo
9,489 people viewed this question
Top Eclipse Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
john h
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
