Low Beam System Operation
The headlamps may be turned on two different ways. First, when the end of the of the turn signal/headlamp switch lever is turned to the second detent position, the headlamps will illuminate. A ground signal is provided to the DRL control module. The module then provides a ground path to the coils of the HLP relay. Since the head relay is provided with battery voltage to both the contacts and the coil, the coil becomes energized and closes the contacts providing voltage to the DIM relay. With voltage and ground provided, the low beam lamps light. Second, with the switch in the OFF position, for automatic lamp control (ALC). During ALC the headlamps will be in one of the following modes of operation:
• Daytime running lamp (DRL) operation in daylight conditions, refer to DRL below for the operation of the circuit.
• Low beam headlamp operation in low light conditions. When the ambient light sensor senses a low light condition for approximately 15 seconds, it will cancel DRL operation and turn on the headlamps at 100 percent intensity. A path to ground is provided to the coil of the HLP relay. With a direct path to ground provided to the headlamps though the DRL control module, the headlamps will light at 100 percent intensity.
High Beam System Operation
The high-beam headlamp operation is controlled using the turn signal/headlamp switch lever on the steering column. In order to change headlamp operation from low-beam to high-beam, push the switch lever toward the instrument panel (until the detent is felt) and release. With the switch lever in the high beam position, ground is provided to the DRL control module through the turn signal/headlamp switch and splice pack 200 to G200. The DRL control module provides a ground to the coil of the dimmer relay. Since voltage is being applied to the dimmer relay coil, it becomes energized. Voltage is then applied through the closed contacts of the dimmer relay and the to the high beam lamps in the headlamps. Since ground is provided to the headlamps through the closed contacts of the energized DIM relay, the high beam lamps light. The high-beam indicator (blue) in the instrument cluster will light during high-beam headlamp operation. In order to change headlamp operation back to low-beam operation, pull the turn signal switch lever toward the driver (until the detent is felt) and release.Your best bet , take it to a qualified repair shop.
SOURCE: 2000 pontiac bonneville wiring harness
u can get one to use out of a srvice book at the libruary
SOURCE: Radio Wiring Diagram
Go to www.crutchfield.com.
On the bottom of the page there is a link for product support. On the next page, type "2005 Grand Prix" in the search box and hit enter. The top link shows an image and pinout on models with Monsoon sound systems, the second link for ones without.
Hope that helps! Good luck!
SOURCE: wiring diagram for 1988 ford f250 4x4 460 cu in
Try having a look here:
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152801cd403
Hopefully this gives you what you need. If not, I can keep searching or see what else we can do.
SOURCE: 2005 Pontiac Vibe suddenly won't start.
nutral safty switch try moving the shifter from P ... to N....P....N....P.....N
SOURCE: 2006 Pontiac Vibe need serpentine belt routing
THIS SHOUD BE ON A DECAL SOME WHERE T UNDER THE HOOD IF NOT GO TO YOUR LOCAL PARTS STORE
