Or if ignitor to start heat bad element
The issue could be several thing,s but a couple of thoughts given the age of the dryer and home.
From a dryer standpoint sometimes the dryer drive motor fails by shorting out internally. The electrical short will cause the breaker the blow. If you are handy with a digital multimeter check for continuity across the motor.
From a home standpoint, the circuit breaker over time can wear out and trip early below the rated amperage. Since it is a gas dryer that is probably not the issue but check the wall outlet the dryer is plugged in to by testing another appliance with similar amperage draw.
Good luck with your troubleshooting!
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
SOURCE: Amana ALG443RAW Gas Dryer will not heat up.
you can remove the lower acess panel (2) 5/16 screws along bottom. youll get a good view of workings there. turn on dryer (make sure a heat cycle is selected. you should see the ignitor light with in a few secs. if not unplug the ignitor(small white connector maybe 6inhes back from ignitor itself) and with a meter ck for 110v in that connection when unit is turned on, if you do have 110volts , you hav abad ignitor. ifyou dont get 110 volts you need to check the thermostat(s) located on top of the heater box right above the ignitor, if no continuity you need a new thermo.
SOURCE: kenmore dryer
first dryer should be on circuit by itself..if dryers runs ok for a while before tripping breaker call electrican to change breaker..change it not ck it ..too many times had electricans tell cust breaker ckd ok but after explaining to cust a breaker can not be ck without load they had breaker changed and solved problem ..not just old breaker but even new ones can cause problems..if breaker kicks as soon as dryer is turned on ck wiring at connection where ac is connected very seldom does any other issues with dryer cause immediate tripping of breaker
SOURCE: My white westinghouse dryer blows
hi i have the same problem but with my simpson sirrico 350 with auto reverse anti tangle dryer ,i walked out after putting a load into the dryer to find the dryer had not dried the clothes and water was leaking from the front of the machine where the dials are,i left it a few days then tried to turn on but it triggers the circuit breaker (safety switch on my house meter box.can you please help me with any suggestions on how to fix the machine as i only bought this approx 2 -3 years ago thankyou sharon
SOURCE: where is circuit breaker in a LG DLE9577WM dryer
it could be the thermostat it could be a burned heat element if electric verify gas or electric
