20 Most Recent Amana NDG2330AW Gas Dryer Questions & Answers
The buzzer is not adjustable on your model.
Amana NDG2330AW... | Answered on Dec 21, 2011
You dis-assemble the interior of the dryer and re-route the exhaust vent to the rear.
Amana NDG2330AW... | Answered on Jul 17, 2011
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Amana NDG2330AW... | Answered on Oct 06, 2010
If the igniter is glowing and even sometimes lights the burner, it's not the igniter that's bad. I've created a checklist that most homeowner's can use to trouble shoot dryer lighting problems. Click on my username, scroll down my profile to my tips and tricks for trouble shooting gas dryers.
Hopefully, one of these tips will solve your problem. Good luck.
Amana NDG2330AW... | Answered on May 18, 2010
Well it could be a problem with the flame detecter. 287476c.jpgWith age the bi-metal tends to take a lot longer to reset so that the ignitor can begin another heat cycle. The ignitor is either gonna be good or badff65907.jpg no in between. The coils that open the gas valve tend to get hot and short out with a little age.4c17c1c.jpg That is a common problem with these good old gas dryers. You need to inspect the blower housing and filter area for air restrictions.a0d89cc.jpg Lets see what else? Oh yeah the control mounted on the blower housing could be bad. It has 4 terminals,3829896.jpg 2 small ones that operate a heater that heats up the bi-metal disc inside to make it shut down faster for knits and permapress stuff. Clever ain't it? Note:These photos are correct in nature to this response but not specific to your model. Now that you have an idea what to look for you need to be sure and order the exactamundo by using your model number amigo. Get parts:
http://www.appliancepartspros.com/partsearch/
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Amana NDG2330AW... | Answered on May 08, 2010
Check and make sure your exhaust vent is clean and clear of any blockage.
Amana NDG2330AW... | Answered on Oct 10, 2009
Bubble test!
Amana NDG2330AW... | Answered on Jul 30, 2009
The manual for the W10562495A has a copyright date of July 2013. Since this is a fairly new dryer, I believe it has an on-demand igniter instead of a standing pilot light. Most gas dryers stopped including a pilot light in the 1980s. This is much safer since there is no danger of the pilot going out with the gas still flowing.
If your dryer is not working, check the gas solenoid and the igniter. (Use the data sheet that should be inside the dryer. It may be behind the control panel.) If you live in an area that had a history of mining, check your ventilation. I have to open the garage doors to my home after some storms to get more oxygen into the basement. The gas appliances will give an error about "failing to ignite" if I don't.
I hope this helps.
Amana Dryers | Answered on Jul 14, 2020
The issue could be several thing,s but a couple of thoughts given the age of the dryer and home.
From a dryer standpoint sometimes the dryer drive motor fails by shorting out internally. The electrical short will cause the breaker the blow. If you are handy with a digital multimeter check for continuity across the motor.
From a home standpoint, the circuit breaker over time can wear out and trip early below the rated amperage. Since it is a gas dryer that is probably not the issue but check the wall outlet the dryer is plugged in to by testing another appliance with similar amperage draw.
Good luck with your troubleshooting!
Amana Dryers | Answered on Jan 24, 2020
Means an HEating (heating) error. You may have a burned-out heating element, or an open thermal fuse.
Amana Dryers | Answered on Sep 23, 2019
The currant draw of the unit is higher than the rating of the in line circuit breaker causing it to trip, points to a faulty unit have it repaired.
Amana Dryers | Answered on Sep 15, 2019
If the igniter doesn't glow, then you probably have a bad igniter! You can use an ohmmeter to test it. Unplug the dryer before you start working on it. then take the dryer apart until you can get to the igniter. Unplug the igniter plug, and measure it's resistance. If it's less than 100 ohms, then it is okay, but if it's reading over 1000 ohms (or an open circuit), then it is bad and needs to be replaced.
Amana Dryers | Answered on Sep 02, 2019
E 5 Usually means open fuse. Usually a secondary fuse behind the cover where the Blower is. If you change the fuse and still have no power you have a wire issue. Could be a loose connection, or a wiring shorting out somewhere.
Let's hope the fuse takes care of it. Be sure to unplug it before. Checking anything. 220 volt will hurt you. Hope this helps you..
Amana Dryers | Answered on Aug 21, 2019
The igniter or gas valve could be defective.
Amana Dryers | Answered on Jul 15, 2019
Amana NDG2330AW Gas Dryer Logo
7 questions posted
Top Amana Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
jdthefixer
Are you an Amana Dryer Expert? Answer questions, earn points and help others
View Most Popular
Amana Dryers
  • Amana Dryers
Most Popular Question
amana dryer runs took vent off saw glow
  • Dryers
