How to set up the headphone with mic attachment and my destop speakers are are seperately
How to Hook Up a Microphone and Headset to a Computer
In the past, business professionals used telephones to conference with customers or employees, but applications like Skype have made it simple for all users to voice and video chat with one another long-distance. Having a good audio configuration is critical for workers who often need to touch base with clients or other business professionals. Headsets allow users to both listen to and talk to others hands-free, but sometimes the mouthpieces attached to a headset aren't of the best quality. You can connect the speakers on the headset to the computer but hook up a separate microphone to the PC to use instead of the headset's mouthpiece.
1.
Plug the headphone connector on the headset to the green-colored jack on the back of the desktop PC or into the headphone jack on the right or left side of the laptop or netbook.
2.
Connect the microphone to the pink-colored jack on the back of the desktop computer or into the mic jack on the right or left side of the laptop or netbook.
3.
Click "Start ' Control Panel ' Hardware and Sound ' Sound." Select the headset on the Playback tab and then click "Set Default" to use it instead of the computer speakers. Click "OK."
SOURCE: Intel D101GGC Motherboard front headphone mic not working becoze wire not attach in motherboard
Simple dear connect the wire on Motherboard. The pins you will get near the outer portion of your motherboard.
SOURCE: Headphones with mic / external speakers
Does your computer have front audio ports? If so, you can just plug it in there. Otherwise you need a single male 2 dual female converter to plug into the speaker port.
SOURCE: Mic not working and audio coming from both headphone and internal speaker of laptop
solution:
If further assistance is needed, email me at: "admin [at] tejenmail [dot com]"
I used to have the same issue with my HP Pavilion HDX9010NR (HP and Compaq is the same thing)
SOURCE: speakers sound hollow. mic in sounds like squirrel
i think you're driver did not do the right setting for you. try searching drivers from this site http://www.rudytarigan.com/laptop/toshiba-satellite-l310-drivers.htm or search realtex HD manager. They will do all the work for you
SOURCE: The external speakers attached to
It is NOT likely the keyboard is "killing the speakers"... OR the headphones for that matter.
I suspect the problem is bad switch contacts in the headphone jack that cut off the speaker line outputs when headphones are plugged into the pro keys. These jacks are, to put it bluntly, JUNK... they are EASILY damaged by pulling the cable plugged into them sideways. You will need to service the unit.
