Most cassettes have 5 screws that hold them together. You simply unscrew them. If the cassette is sealed. Then you will have to cut with a sharp tool all along the centre of the cassette edge till it comes apart. Once you have joined the tape together, purchase a new blank cassette tape and unscrew the screws and discard the new tape and place the old tape into the new case.
Without physically looking at the cassette deck myself, I cannot be 100% sure the tape is wrapped around the pinch roller and capstan. The capstan is the chrome rod which the rubber pinch roller pushes to regulate the speed of the tape moving across the head. However it is approximately a 90% chance the take up reel for the tape stopped working from a bad tape or a loose belt which drives the tape take up reel. The clicking sounds like it could be the auto reverse solenoid because it thinks the tape has reached the end of play. The fun part is to remove the tape which you may have to disassemble the front panel if you cannot gain access to the tape from the top or bottom. You will need to cut the tape and remove it from the capstan and pinch roller to open the cassette door. Sometimes you can remove the capstan to free the tape. Once you have cleaned all the tape out of the unit make sure the belt for the take-up is good. If it is glazed, cracked, loose or broken order a belt. Clean all the pulleys and capstan and replace the belt. Your unit should be functional after the above procedure.
