Lenoxx Electronics CD-102 Cassette/CD Boombox Logo
Question about Lenoxx Electronics CD-102 Cassette/CD Boombox
Lenoxx compact disc player stero cassette recorder; manufactured March 2001; model CD210. The problem - The unit will not play CD's nor cassete tapes. I have used the CD cleaner kit as well as the cassette cleaner kit. No positive results. At least the CD will run the CD as if it is going to play and when it finishes, it just stops. The cassette tape player will not even turn the cassette tape.
Posted by ms_oakley on
Anonymous
  • 8,546 Answers
Does it fail on AC power, too? Motors draw a lot of current. Batteries may be weak.
Posted on Jan 18, 2011
Convert cassets to cds on classic recorder model cdr200
Connect the Play or out from the cassette and connect to the rec or in on the CD recorder using some descent RCA cables. Good luck!
How can I record a music cassette to a music disc on my Magnavox DVD recorder/ VHS --Model # ZV427MG9
You can't burn a CD-A with the ZV427MG9. The unit will not burn to a CD to play in a CD player.
You may be able to record the audio to a DVD with no video source. Connect your cassette player to the Line In audio ports (L/R) at either the back or front of the unit. Depending on your cassette player, you may need a 3.5 mm M to RCA F/F adapter to connect the RCA audio cable to the cassette player's headphone jack. Do not connect a cable to the video input of the composite input unless you have a video on a camera or something to play back. This means that the recorded video may say "No Signal" or will be black or static. (Note: this may not work with this signal issue.)
Set the unit to record to DVD on L1 or L2, as needed, by pressing Source on your remote. Advance the cassette to where you want to record. Press Rec on the DVD unit and then press Play on your cassette player. If you want to identify tracks, Stop the recording and play back and then press Rec and Play again. You are at risk of having issues with the volume during the recording. Clipping of overly-loud sounds and distortion is possible.
When done, finalize the disc, if desired, to play the disc on other DVD players.
If you want to make an audio CD, you would be better off using a computer and connecting the cassette player to the Line In jack of the computer. You do have to make some adjustments to avoid recording the default Microphone input. Use a program like Audacity or any other audio editing program. Record the signal and divide it into tracks, if needed. Now you can filter out any distortion as well. Then save as a WAV file. Use a different program to burn the WAV files to a CD-A. (This must be burned as a mastered disc; my attempts that worked on an older CD player failed if there were gaps between the tracks. Lots of programs will do this; Roxio Creator is one option.)
The manual for the ZV427MG9 is available here: http://download.p4c.philips.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf .
I hope this helps.
1helpful
Replacement power cord for CD-109
Hello
1_5_2012_5_44_43_pm.jpgCompare these power cord pictures and get it from any electonic spare part selling shops at your town. It is an easly available part. OK.
I need a power cord for RP-7986 AM/FM Stero Radio/Cassette Recorder/Compact Disc Player.
Depending on where you live, you can find them at Radio Shack, Walmart, most discount electronics parts stores,etc.They are universal except for the physical plug style at the unit side. Best bet is to take the unit with you if possible for a perfect match. Hope this helps
Hello, i need an owners manual for a lenoxx cd-88 player - download, please
My model CD-88 programmable compact disc player player will go around but no music comes from it. It is one that you can use in your car tape player as it has an adapter. What is wrong with it ? Thank you. Estella Huffman [email protected]
2helpful
2answers
I need a new power cord for my Lenoxx stereo cassette/ CD player model #CD-102. I hope I am sending this the right way, I am not very good on the computer.
if it is a plugin (socket at the back of the stero) then you need to call the vendor to order the power cord. if it is a build in (internal connected) then you can get any power cord and repair it by opening the stereo and repair the cord.
4helpful
4answers
KOSS CDR200
can I record from an outside source, like a casset player to cd, on the cdr200, if so, how, thankyou
Trouble playing store bought cd's
itll be the lens on the player clean it with surgical spirit
Top Lenoxx Electronics Audio Players & Recorders Experts
Marvin
Marvin
Are you a Lenoxx Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
