My Bosch dishwasher isn't working correctly. The water flows in very weakly during the cycle and doesn't have any power at all to spin the wash arms and clean the dishes. The water is heating and the machine moves through all the cycles...fills/drains etc... just no powerful washing action. any help would be appreciated.
It all stems back to your incomming water supply. Either the sieve is dirt or the valve is blocked with sedementation. Some valves are servicable and some are not,if your valve has screws then its revicable. (low water pressure restricts movement on arms.)
If all the wash action is correct, then its definately the water supply. If it comes into the unit slowly,the water is not sufficient to turn the rotors correctly. Having the correct amount of water in the system is like having the correct voltage running an appliance. Anything other than the correct value, machine wont operate corectly. Suggest
Sorry for two part answere , computer doing its own thing. Remove pipe off of dishwasher and you should see a small plastic or metal sieve, either in the valve inlet or in the water pipe. . Take it out and clean properly. Otherwise replace incomming water valve If it is not servicable.(You will see normally 4 screws which can be removed. carefully remove and clean dirty areas.then replace.
You're thinking incoming supply vs. pump?
