You can get guide from many sites.. i know few
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete.. eg. pls try reliable-store.com
Sounds like one of the pins on the cable from your transducer is bent where it plugs into the back of the unit. check that first, then ensure the plug is all the way in. If it's not that, it's possible a wire is broken in the cable. You could try the wiggle test. With the unit on, have someone watch the screen and wiggle the wire that you can reach working from one end to the other. if the screen flashes or changes while you do this in a certain spot, there's your problem. This kind of problem usually comes from the wire being tight where it goes around a corner. Heat and vibration will finish the job
