Question about Lowrance Boating
Hi all my lowrance elite only today had a stopped come on screen ? So have no sonar or basically anything? Looks all plugged in ?? Any suggestions??
Posted by Angelo on
SnellsBeach Comber
    New Friend:
Hi. Go to sonar menu, last item is stop sonar press this and all should be good. Cheers
Posted on Jan 12, 2019
5 Related Answers
Anonymous
  • 113 Answers
SOURCE: I have a Lowrance LMS
Are saying you can't read the screen at night, or is it hard to read the screen anytime?
If you tap the power key, you should here a beep and the screen should get brighter. If you hear the beep and there is no light, then the internal light has failed.
If you can't read the screen in normal light conditions try viewing it under a bright light at various angles. You may notice that the screen is just barely visible. If this is the case you may be able to fix the problem by adjusting the contrast. Try tapping bthe power key and then tap the right or left side of the track pad. It may take several taps to see the results. If left or right doesn't work, try up or down.
Posted on Jul 21, 2008
Anonymous
  • 113 Answers
SOURCE: Globalmap 2000 sonar not responding
Not enough info to diagnose your problem. It sounds like a networking problem. I couldn't find a manual for the sam-st module so I'm not sure how you have it hooked up. Typically with these devices only one would be hooked up to the SONAR module, and it would then share the data with the other display via an ethernet or NMEA2000 network. The erratic behavior of your bluewater could be due to some sort conflict with the current coming from the GlobalMap2000. Do you get the same problem when the 2000 is turned off? Have you tried running the GlobalMap2000 with the bluewater turned off?
Posted on Aug 19, 2008
Anonymous
SOURCE: My lowrance 522c has never worked quit right i
i seems water has gotten into my unit and shorted it out
Posted on Aug 29, 2009
Anonymous
SOURCE: Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System: I have a Lowrance LMS 520C on my boat. The GPS wi...
I have the same problem on my 520C.
I have no solution but I hope you have find some?
Best regards
Dan
Posted on Oct 31, 2010
Anonymous
SOURCE: lowrance 330c gps not responding
do you have both power and ground wires hooked up?
Posted on Jan 12, 2011
My lowrance elite 4 HDI goes black when i get on plane so my backtrack feature doesnt work
The speed of your boats travel only directly affects your sonars ability to read the water depth.
your backtrack feature is GPS based. These is not affected by your boat being on plane.
Your screen being black sounds like your sonar is losing bottom contact due to air bubbles passing under the transducer. This is a common occurrence with most boats.
Add some details regarding what your seeing and we can help you get a better handle on your difficulty.
May 24, 2015 | Lowrance Boating
What are the best settings for a Lowrance Elite 5x for freshwater use only. Applicable to Sensitivity,noise rejection and water clarity settings
Noise rejection = low
surface clarity = off
in the menu, sonar options choose "bottom color tracking white background" this will make the lake bottom appear brown and r he fish bright green.
Automatic sensitivity, but you can adjust it up or down to filter out background clutter and the unit will honor your settings.
Feb 27, 2015 | Lowrance Elite 5 X Color Sonar
How do i disable the depth sonar
There is a selection either under sonar options or the main menu sonar tab that allows you to turn the sonar off. Article Details
here is a link to Lowrance to download your users manual in a PDF format.
Oct 17, 2014 | Lowrance Elite-4 DSI Combo with 455/800kHz...
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Lowrance screen
Mine was doing the same thing. Hold the plus and minus button at the same time and hit the power button
Jul 28, 2014 | Lowrance Elite 5 X Color Sonar
How to change language to enlish
Hi Kane,
I have this manual for you on how to set up setting up Language on page 42 to 43. Hope it helps.
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-7_HDI_OM_EN_988-10423-001_w.pdf
Apr 25, 2014 | Lowrance Elite-7 Hdi Sonar/Gps Combo,...
Lowrance Lms 522c 5" Screen Color Internal Gps And 200 Khz Sonar
If it is normal in deeper water, it is most likely just returning stuff in the water (debris, algae, anything floating around...choppy water can cause this). Try installing the latest updates from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If it doesn't help, adjusting the sensitivity or setting the SURFACE CLARITY option from the SONAR FEATURES menu to LOW, MEDIUM, or HIGH...whichever gives the best results.
Jun 09, 2009 | Lowrance Lms 522c 5" Screen Color Internal...
Boating Logo
193 people viewed this question
Top Lowrance Boating Experts
Ekse
Mike
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
