How hot is your water in your home? Newer dishwashers do heat the water but they still require 140 degree water coming in. Also the detergent you use can make a difference. Cascade complete costs more but continues to be the best. Also you can run a cup of vinegar in you washer without and dishes in it to clean it or you can use this stuff they sell in the store called dishwasher magic. Make sure your dishwashers filter is clean and the drain check valve is working. If the check valve is stuck dirt dishwater will flow back into the dishwasher causing dirty dishes.
Make sure you water is hot enough, manufactures reccommened 120 degrees to the dishwasher, i advise all customers to run hot water at sink til you get hot water then turn dishwasher on, also fill both compartments of sopa, also use rinse aid or jet dry, do not use gel packets. use cascade powder or liquid only.also run the unit through a clean cycle this should be done once or twice a year. letdishwasher fill with hot water. when starts to wash, open door and add 2 cups of white distiilled vinegar and close door and let it go throughas cycle. no dishes. also i reccommened dish majic cleaner sold at walmart or grocery stores. if this dont help then youw wash syatem could be bad or going bad.hope this helps you. try all these things first befor you re[lace uniy or pay to have it looked at.
