20 Most Recent
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Questions & Answers
Husqvarna LT-18542 lawn tractor dies after it is started. Carburetor was cleaned ignition coil and spark plug are good.
Check that the ignition module and the fuel solenoid remain powered when ignition switch returns to the RUN position.The mOOOoof sound is the leaf valve in the crankcase breather. As the engine spins down and the crankcase pressure drops, the leaf may resonate. Some do some don't.As a test you might try adding fuel (starter fluid, carb clean, or combustible brake clean). Remove the air filter and as it dies spray a shot of fluid into the carb throat. If it picks back up you know it's a fuel problem and not ignition.
I have a husqvarna 26
The engine is not charging, you need to have the charging system checked out, could be the charging coil or the rectifier.
How do I rewire lawn mower
The best way is to order a complete harness. This will cost about $100 but it is the easiest quickest and best way to complete this task.
I have a Husqvarna GT 2548 riding mower with a 25
Hi, It sounds like a lack of fuel supply when it is required. When it idles, the demand is sufficient for this, as soon as a demand is required, there is a lack of fuel supply to meet the demand.
Is the fuel old? if it is, you need to drain it and put fresh in. You say it's sat a long time. It's possible that fine particles of metal has built up in the tank and passing up to the carb. You will need to strip down the carb and check to make sure there is no sediment in the float chamber, that the floats are not sticking, and the jets are clear.
I hope this is of use.
David
Replcement oil filter husqvarna model ltg2654
their are a few different filters for your rider --these are for the kohler 26 hp motor stores like home depot- lowes- sears- or small engine repair shops carry filters K&N PS-1002 http://www.sears.com/ayp-genuine-ayp-part-578416804-oil-filter-kohler-cou/p-SPM8242278631?redirectType=SKIP_LEVEL http://www.knfilters.com/oil_filter/all/kohler/sv735/26hp
