Computers & Internet Logo
Posted on Aug 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell Poweredge 4300 Bootup problem after cmos battery replacement
  • 1 more comment
  • trowbridger Aug 22, 2009
    Just above the ISA clear there is one labeled Card_Bios
    the one labeled card_bios has no jumper installed from the factory
  • Anonymous May 11, 2010
    is there a jumper on the motherboard for reseting the bios?
Anonymous
Level 3:
  • Master 797 Answers
  • Posted on Aug 22, 2009
Anonymous
Master
Level 3:
Answers
797
Questions
Helped
213973
Points
1924
Check the version for the Raid Controller. This may need to have the firmware to be upgraded. If the controller is removable, take the controller out and then see if the computer will continue past the bios. If the controller is built-in, then disable it in the bios, and try to see if it will get past the controller setup.
On most system I have worked with, if you are booting from a scsi hard drive, then the bios cannot be set to let any IDE to boot, or the bios must be set to no hard drive to boot. There may be two places in the bios which must be set to no hard drive. Another setting which may make a difference, is the scsi boot setting, if it has it. Another chance is that something is wrong with either the cabling or the controller itself.
As far as the jumper, that may be the erase bios jumper. Usually though, you have to move the jumper to one of two, sometimes three or four jumper. You would simply move the jumper to the erase setting, and then move it back. However, by doing that, you will lose all setting which had been set. Also, if the computer will go past the bios when the controller is removed, that could also mean some thing is wrong with a drive, or the boot drive is not set right in the controller bios. If a scsi drive is a boot drive, that boot drive number must be set right in the bios of the controller.
CMOS Battery replacement
Hello here is a link to the homepage:
http://search.dell.com/results.aspx?cat=sup&s=gen&c=us&l=en&cs=&k=replace+CMOS+battery
And here is the download site for drivers:
http://www.dell.com/support/drivers/us/en/19/Product/poweredge-xeo6650
Try also to upgrade the bios. just make sure its the right model.
You maybe have to set up the boot settings when you replace the cmos battery or renew the bios.
Good luck
Dell Poweredge 1800 server not start, i press power button but nothing hapened
Your Model of Dell Poweredge 1800 server may not have a redundant power supply. The power supply is the most like cause of the problem. order a replacement power supply and replace the faulty unit.
We have a Dell Poweredge 4400 & a Dell Poweredge 2300. Both have amber lights blinking - hard-disk failure indicators. They are using RAID. What do I need to do?
Go into the RAID setup during bootup (not always in the BIOS), but will post somewhere on startup (should say SCSI/SAS Controller card press CTRL + M to enter setup) or similar.
When in the raid setup check to see the status of the drive(s).
Was the machine running and it's just happened etc or are these machines you have obtained and are plain not working?
What audio driver to i need for my dell poweredge 600sc server running windows server 2003? Is there a direct link? I search and have not found anything.
dell poweredge servers are not needed for sound. DELL support will not support any sound cards or care anything about your audio issues. You will not find audio drivers because again, a server's purpose has nothing to do with audio.
1helpful
2answers
Dell Poweredge 4300 will not boot up after cmos battery replaceme
Configure your System bios and reboot. Your Hard disk drive was not configured. Pl configure. it will work properly
1helpful
Dell poweredge 4300 Bootup problem after replacing cmos battery
Look for a jumper on the motherboard where it would allow you to clear the cmos. basically you would move the position of the jumper and turn on the computer and let it clear itself.
Then after it clears turn off the machine, put the jumper back into its original position and then turn the computer on and see if the message goes away.
Also go into the BIOS and put in the correct time, date, year, etc.
Bootup Problem of Dell PE6650
Your NVRAM was corrupted (probably by a dead CMOS battery) or your hardware configuration has cnaged (deah boot disk, etc). Enter setup to see if the date/time has reverted to a previous date. If so, the CMOS battery needs to be replaced and the BIOS reconfigured for the server. Otherwise, check to ensure that your disk configuration is correct. If the battery is not dead and your disk configuration is incorrect, you may have a bad hard disk.
Grand Canyon Tech
Grand Canyon Tech
