Hi there, My problem with my Samsung j700 is.. after getting it back of my son he has forgot the code to disable the sim lock, I install my sim card and im asked for the sim code to disable the sim lock. Any advice to this would be great.
That's a big problem.. your phone can't no longer help on how to disable the sim lock unless your son knows the code and disable it using your phone.
if he do, then go to settings then go to security settings (11) then go to sim lock (2).. turn it off and that's it.. just key in the correct code.
you can unlock your phone here http://www.theunlockspot.com/samsung/rs10wp8/ They will provide the code when you enter your imei number,you just need to select your phone model and network provider
1- Power on phone, type : *#7465625# you will identify which code is active , which is inactive
2- Remove battery, Put your sim card, not all of it, just to prepared for it to be full inserted, put your battery back and power on phone, you must see " insert sim" not "invalid sim.."
3- type : *2767*3855# your phone should restart after 1 min, now, and before it restarts, push your sim card in, without removing battery.
4- your fone should work and accept the sim card ,, but if you chek locks you will find that your fone is still Loked
5- now type : *7465685*638*00000000*00000000# your UNLOCK CODE is 00000000 now , Enjoy
6- now , back to Locks table with : *7465625*, and for each active code you can disable it, here details :
Please follow the instructions carefully but if the code fails to work, then ,make no more than 4 attempts as it may lock your phone. Can you let me know how you get on with it as well please. Thanks. Please also make sure that you back up any information on your phone as in certain cases the resetting also removes your contacts from the SIM and your pictures.
j700 unlock method
Basically the SP lock needs to be removed before the Network lock is disabled, so if you only have SP lock on, you need to turn the Network lock back to active, disable the SP lock and then disable Network lock. A reminder 'how to' is below:
Do a custom reset:
*2767*2878# once this has finished rebooting turn the phone off.
Next a SIM card from a different service provider needs to be pushed half in - (Push it fully in then slide it back out by about 1/2 a centimeter),
Turn on the phone - you will now see an "Insert SIM" message,
Now perform a full reset:
*2767*3855#
When the phone powers off, quickly push the SIM card fully in, and let
the phone power back up.
After you do the reset, check and make sure that your Network lock is active by pressing *#7465625#
If it isn't active you must use this code to reactivate it:
*7465625*638*00000000*00000000#
Then you have to deactivate the SP lock first. To do that you need to input:
*7465625*77*00000000*00000000# (this will reset the lock)
Then you enter:
#7465625*77*00000000# (to disable the SP lock).
Then you disable the Network lock:
#7465625*638*00000000#
j700 unlock method
Do a custom reset:
*2767*3855#
Then you enter:
PUK is a code used to unlock a sim card if it has been blocked by entering incorrect PIN numbers. The codes are usually supplied with the sim card. If you don't have the original sim packaging or codes you have to get your puk codes from your service provider.
Do a custom reset:
*2767*3855#
Then you enter:
