Hi I have a problem with a works Philips DVDR3380/05 player finalising the disc at the end of recording. Sometimes it is okay and sometimes not. Is there a particular make or type of dvd disc to use that works every time??
Use Phillips own media this unit was designed with DVD+R/RW in mind, it will work with DVD-R/RW discs but Philips invented the + format.
If you are using the DVDR 3380 is recorded video to then upload to your PC the best program is TMPGEnc v4.0 Xpress it has its own function to scan source media from a DVDR, if you use +R or + RW media you don't even have to finalise it. This is only required if you want to play a DVD-R on another standalone
I have never had any problems with SONY and PHILLIPS media, generally speaking cheap unbranded media will have a higher failure rate , but you do get what you pay for when optical media is concerned.
Hope this helps, join www.windowstipsclub.co.uk for more tips and tricks concerning DVD's
