Well, if it's worked in the past, the most likely suspect is the water heating element -- this is used when "Water Heat" is selected on the controls.
Otherwise, just hot water from your water heater is used -- I'm assuming your water heater is functioning or you would have noticed it's absence. So, the electrical continuity in the heating element should be checked with a multi-meter.
Charlie
It may be connected wrong,,,should be on hot water
No it's not new, it has heated the water fine before. There are various programs with different temperatures attached.
It is not new and has worked fine since we have had it. The only way to control the temperature is to choose the appropriate program. I have tried 3 different ones and all use cold water only.
Is this a new dishwasher? Has it ever heated the water? Is their a selction for "Water Heat" on the controls? Charlie
